Phu Cat1Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  5
Results 1 to 11 of 11
Thread: Rubber Bushing Lube
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Default Rubber Bushing Lube
    Sil Glide for bushings
    Name:  Silglide for bushings.jpg
    2500+ Posts Gold Rush's Avatar
    May 2011
    San Angelo
    Good INFO Jack! I've used silicone grease and spray on rubber bushings for years.
    Jerry "Gold Rush" (aka: "SPOOK") San Angelo, TX
    2015 GL1800/Roadsmith HTS1800
    TOI - IBA #23804 (SS1K & BB1.5K)
    I'm like an old race horse..... I can still run the race -- Just ache more at the finish line and need more rest between outings.
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Could I put some of that on the rubber grommets that hold the side covers on to make it easier to check the air shocks or would it make them too easy that they wouldn't stay on?
    My mission in life is not merely to survive, but to thrive; and to do so with some passion, some compassion, some humor, and some style. – Maya Angelou
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by LadyonaMission View Post
    YES, IT is a very good lube for ALL rubber, I use it on all my power windows and heater hoses. When I taught break class it was the first item up on display, We had a contract with Napa at the time, it is available every where now
    May 2011
    San Angelo
    I don't know about your Freewheeler side covers but I do know Honda GL1800s have a habit of loosing theirs if the grommets are lubricated. I would be VERY CAREFUL putting anything on those grommets.
  6. #6
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Gold Rush View Post
    Indeed, donot use on these grommets
  7. #7
    200+ Posts
    Nov 2015
    palm bay
    That's fine but are they really "bushings" - ie: rubber bearings. The front suspension on older Brit cars used "Hydrolastic" (IIRC) "bushings". These were intended to flex not slip. Unlike a bearing the shaft wasn't supposed to slip inside the bushing. Lubing them caused the shaft to slip, ruining the dampening effect and quickly wearing out the "bushings". I have no idea what H-D uses on the swing are but be sure b4 you lube. Does H-D recommend lubing them??
  8. #8
    May 2011
    San Angelo
    Quote Originally Posted by vito View Post
    Good Point. Could be similar to a torsion axle... HUMMMMM????
  9. #9
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    This lube is NOT a fix all, None are However u use it is up to u, Your Ride U Decide JMO
    Dawn Dish Soap works good on Poly Bushings, try it some time. For installing bushings try freezing them this will shrink em, use the correct driver, use lube only if needed during assembly, it will change the sizing by some .0000 +
  10. #10
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Thats how i installed ''bearings'' in trailer axles .....Freeze them, And you don't have to hammer them in...If i have to install rubber ''Bushings'' , or ''Grommets''... And their a very tight fit i aways use a light coating of White Marine Grease....Note light coating..
    Freezing rubber drys them out....
    2019 Tri-Glide.......
  11. #11
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Not to beat a dead horse, BUT the bushings do mostly survive the freezer, some bushings have an outer skin either metal or another material holding the rubber together, the rubber innards are more affected by heat IE open flame than cold IMO
  1. The Frog Lube trial.
    By Jimsjinx in forum The Gun Enthusiast
    Last Post: 11-03-2013, 08:43 AM
  2. Swing Arm Bushing upgrade
    By zoood in forum Harley Trike Conversions
    Last Post: 01-18-2013, 04:07 PM
  3. drive shaft lube
    By geraldlanc in forum Honda Trikes
    Last Post: 04-11-2012, 09:00 PM
  4. lube procedure
    Last Post: 04-11-2012, 08:47 PM
  5. Replies: 1
    Last Post: 02-17-2012, 05:09 PM
