14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  4
Results 1 to 12 of 12
Thread: First time with a HD Triglide
    10+ Posts jimz71's Avatar
    Aug 2013
    Titusville, FL usa
    Default First time with a HD Triglide
    I finally crossed over. 25 + years with Honda s and Suzuki's. I recently purchased a 2014 HD Triglide with 7400 miles on it. I am having some problems with slipping my gears into neutral. Any suggestions that I should consider ? It occurs most when I am going to go into reverse. Is there some adjustments in the gear box ? I am planning to wait until my next service and ask the dealer to look into my problem.
    200+ Posts Kristie's Avatar
    Aug 2016
    Center, ND
    Congratulations and welcome from central ND! On our 2017 Triglide I find it easier to find neutral by tapping the heel shifter from first gear. I don't seem to have much luck using the toe shifter. Best of luck and enjoy!
    Jim (Gunnar on this site) and Kristie Buschta
    2017 Harley Triglide Ultra, Bonneville Blue/Fathom Blue, too many extras to list!!!
    make sure the clutch is adjusted correctly and then use a good oil in both the trans and primary. oil is discussed in several threads on the forum. congrats on the purchase
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    I agree with Kristi on the heel tap. Have fun on your Harley.
    Quote Originally Posted by jimz71 View Post
    Finding neutral is a common problem, I learned to put it in first, Then just ''Lightly'' tap the heal shifter back into neutral...Also i would check' or have the dealer check the shifter rod for excess slop...Too much play in the rod will also make finding neutral hard...
    Congrats on your ride. Practice, practice, practice. The heal toe shifter takes a little getting used to.
    Jun 2010
    Coram, NY USA
    Congrats on the purchase. What has already been said about clutch being properly adjusted. Also, easiest to get to neutral if still in motion, even just a little bit.
    150+ Posts Triglide1950's Avatar
    Sep 2017
    Chanhassen, Minnesota
    Congrats on the purchase. As several have mentioned clutch adjustment, but I also switched to Belay 85W 140. Really made a difference and mine shifts better.
    Sep 2014
    Box Elder, SD
    Congratulations, I have a 14 triglide that I bought new. It took a little time to get the neutral shift system down. I moved the shift levers lower to the floorboard and always go to neutral from 1st gear with a slight tap of the heel and making sure the clutch lever is fully pulled. Enjoy the trike. Jim
    Bob's Curmudgeon Apprentice
    consitter's Avatar
    Jun 2015
    Ashland, KY
    Quote Originally Posted by Bikerbozo View Post
    This is a biggie.
    60+ Posts
    Apr 2017
    Sunbury
    Welcome, easiest is like they say slip it in while still moving right before the stop. Once you get used to it it will come naturally. Best of riding,
  1. Time for new tires - time really flies
    By dadztoy in forum Outrigger Style Trikes
    Last Post: 05-15-2017, 11:31 AM
  2. First time trike owner and first time Harley owner
    By cruisin in forum Harley Tri Glide
    Last Post: 11-02-2016, 08:36 AM
  3. Comparison 2014 Triglide Vs. 2017 Triglide
    By FRR in forum Harley Tri Glide
    Last Post: 10-24-2016, 08:53 AM
  4. Replies: 2
    Last Post: 06-29-2015, 02:28 AM
  5. A little down time
    By Bill Reber in forum General Discussion
    Last Post: 04-16-2013, 10:27 AM
