Likes Likes:  8
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 21
Thread: Questions about the new Fat Bottom Girl
    Dec 2014
    Grand Junction, Co. USA
    Default Questions about the new Fat Bottom Girl
    It is a 2008 NAVI Gold Wing with a 2010 (I think) Champion Sold axle conversion.
    Here's the questions:
    Answered - Where would I find the Champion label plate that gives the manufacture date? I'm guessing it's a 2010 because of some purchase paperwork that came with it. Could just be a sale contract as it doesn't mention the trike kit.
    Partially Answered - Where do most people hide their garage door opener? On Tweety, I Velcro'd it under the dash. With the added dials for seat and grip heat, that spot is gone.
    Answered - I know the left saddlebag release opens the trunk, On my remote, I can lock the bike, top case and trunk, I can quick release the top case, the unlock button doesn't work. Is this a function of the conversion or is my remote or receiver bad? Maybe a fuse?
    Answered - I am running 40 psi in the front tire and 30 psi rear. Are these good numbers?
    Answered - My favorite grips are the Kury Iso Grips, I've put them on every bike/trike I've owned since they came out. Has anyone tried the ones that fold over the heated grips? And if so, does the heat still come through?
    As my only other trike was an HD Tri, are there any adjustments to oil dip stick levels, coolant levels, etc. that I need to know based on the trike not leaning on the side stand?
    Is there a way to update the maps on the NAVI like the HD plan? Through Garmin?
    Answered- What do Gold Wingers call the top case (BMW term), Tour Pak (HD term), On Tweety, I just called it a trunk, but, with the massive "Trunk" on this trike, calling its the trunk just doesn't seem right.
    Answered - There was also a little silver key with a square head ... I can't figure out what it does.
    Answered - Last but not least, does anyone know what this is? I found it in the Top Case. I'm not sure whether it us part of the trike. It's not even the same pearl white. guessing it's the PO's idea of a joke ... LOL
    Name:  2017-06-28 13.04.12.jpg
    Name:  2017-06-28 13.04.17.jpg
    Name:  2017-06-28 13.04.23.jpg
    I had a bunch more questions to ask, but, did a short ride today and played with all the buttons. I even figured out how to program Home into the NAVI, although I used a house down the block ...
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    The tire pressures usually depend on your personal preferences, riding style and some experimentation. 40 psi in the front may be a bit harsh. My personal preference works best in the 37 to 38 cold psi range. As for the rear tires, I have found 24 to 25 cold psi works the best for me.
    I have the Kury Iso Grips mounted over the existing heated grips. The grip will take much longer time to heat up. Higher heat settings are also required.
    I have heard all kinds of terminology used to call the top rear storage compartment. I don't know what is correct. I do know the kit installer corrects me all the time when I use the term "Top Trunk". He insists the correct terminology is a "Tour Pack". He also calls the large bottom storage compartment a "Trunk". I like to call it the "Bottom Trunk". The copilot comprehends "Top and Bottom Trunk" much easier.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by David357 View Post
    T
    A Rose by any other name...........
    2019 Tri-Glide.......
    Dec 2014
    The reason I started at 40 psi in the front was because on a two wheel GW, my dealer recommends 40# to minimize wear. I'll lower it to 38# and try that. I also thought about 24-25# in the rear because that's what i ran in the tri. I figured bump it upside because the GW trike is heavier. (I think, not really sure about that.
    I like top trunk and bottom trunk ... Fat Bottom Girl already has lots o' junk in her trunks.
    Jun 2008
    Lovington, NM, U.S.A.
    Does the key look like this?
    They get used on the gas door and any other locks
    Retired trike builder
  6. #6
    Dec 2014
    Quote Originally Posted by trike lady View Post
    Hmmm .. mine doesn't have the black part, but the key part is close ... I'll try it tomorrow. Thanks.
  7. #7
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    I think the plate is on the right side of the swing arm.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
  8. #8
    Dec 2014
    I contacted Champion on their web site. Got a very nice reply from Bill Swift. He told me he would send me a maintenance guide and install instructions via email. He also told me where to look for the manufacture date. FYI it's located on the swing arm right side. Metallic sticker with numbers starting in 7. The remaining numbers are the date.
  9. #9
    2500+ Posts Gold Rush's Avatar
    May 2011
    San Angelo
    Did I miss a question about the key? Or what. Trike Lady showed a modified key used in the gas lid and secure storage release locks. This will not open the trunk release or operate the ignition. I've used these on all three GL1800s I've owned.
    As mentioned earlier, tire pressure is a personal thing. Depending on riding style and desired comfort level those numbers can be played with. Also the suspension presets will come into consideration for handling and comfort.
    There are upgrades for the NAVI maps but I don't know much about that. Someone will chime in that does I'm sure.
    Jerry "Gold Rush" (aka: "SPOOK") San Angelo, TX
    2015 GL1800/Roadsmith HTS1800
    TOI - IBA #23804 (SS1K & BB1.5K)
    I'm like an old race horse..... I can still run the race -- Just ache more at the finish line and need more rest between outings.
  10. #10
    3250+ Posts hogmemberisold's Avatar
    Nov 2016
    Shepherdsville, Ky, USA
    Default Replace garage door opener
    I installed this when it was known as Flash-2-Pass. I have it on both bikes and now the cars. Works great!
    Don't leave home without it!
    Flash To Open
  11. #11
    3000+ Posts Ed Hobgood's Avatar
    Jan 2011
    Dexter, MO, USA
    Congrats on the new trike Fuzzy, I must of missed it earlier.
  12. #12
    Dec 2014
    Quote Originally Posted by hogmemberisold View Post
    Flash To Open
    After reading their info and reviews I think I might order one of these ... do the car remotes still work or do you need to get a transmitter for them as well?
  13. #13
    Dec 2014
    Quote Originally Posted by Ed Hobgood View Post
    Thanks ED ... it is sooooo kewl to be back in the saddle again. Still having issues with bugs in my teeth because I just can't seem to stop smiling. Might have to get a tall windshield.
  14. #14
    Nov 2016
    Your existing remotes still works as before. I've slowly replaced my existing remotes thru the years. We have one remote left because the car has LED headlights and I don't want to mess with it.
    The F2P receiver wires across your existing open/close button in the garage....
    BTW, nice trike.
    WOW, an elusive 08 God Wing
  15. #15
    JustWings.com
    Tech Contributor
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Yes ... it's not a static oil level read. It's a dynamic read. Meaning that it must be done by doing the following as the oil is still dripping into the sump area.
    - on a level surface, run at least 3-5 mins
    - tune off and check between the level between the 2-3 min mark
    to check ... unscrew the dip stick and have the "MCA" pointed rearward. Do not screw it into check.
    Here is your option.
    https://goldwing.garmin.com/goldwing/site
    That is not an OEM part. I've never seen that in the aftermarket world either.
    Please keep in mind that anytime I share or give advice about a motorcycle, unless I state otherwise, I am always referring to GL1800's and no other.
  16. #16
    JustWings.com
    Tech Contributor
    May 2016
    On page 2 rear tire pressure is 20-25psi. Your front pressure is on a sticker on the underside of the trunk lid. I'm sure it says 36psi.
    http://championsidecars.com/wp-conte...enance-R14.pdf
  17. #17
    Jun 2008
    Not sure what the white piece is. Could be from something else and just left over.
  18. #18
    Dec 2014
    I got my emails from Champion today. They included an installation instructions and maintenance notes. I was surprised to see 20-25# in the rear. I will lower the pressure to 25# and play with the pressure like I did with the tri.
    I also like that they include part # for the rear brake pads, and the right oil for the rear end. Pretty detailed.
  19. #19
    JustWings.com
    Tech Contributor
    May 2016
    Lowering the air to 20 or 22 makes for a softer ride.
  20. #20
    1+ Posts
    Jun 2017
    CHARLOTTESVILLE
    Flash To Open
    Thank you for the kudos! The product is still called Flash2Pass. The company is new (Flash To Open LLC) and the product has recently been relaunched. It's all made in the USA!
  1. Kevin Teaches the Fat Bottom Girl a New Trick
    By FuzzyWuzHe in forum General Discussion
    Last Post: 06-28-2015, 07:33 PM
  2. Fat Bottom Girl aims for a swim
    By FuzzyWuzHe in forum Harley Tri Glide
    Last Post: 05-09-2015, 01:35 AM
  3. Fat Bottom Girl's got an Issue!
    Last Post: 05-05-2015, 11:36 AM
  4. Fat Bottom Girl hitches a ride!
    Last Post: 04-14-2015, 02:52 PM
  5. Pics of Fat Bottom Girl
    Last Post: 02-20-2015, 04:58 PM
