My bud went to our local HD dealer for a 50k 3 hole service, clutch adjust, belt, etc. While there he was giving the service mgr. a few minor problems. It's a 2010 tri glide.
One problem , if the trans is in 1st gear and eng is to be started, being in gear, to avoid the morning clunk, the Trike would tend to lunge forward.
Second problem, while taking off in first, a lot of clutch slippage was needed in order to get a smooth start, or the clutch would grab abruptly.
Evidently the compensator bolt was loose and it's been a problem on a lot of 2010 - 2012 year FLH's.
Its not a recall, it's a silent recall, meaning, unless you got the symptoms, the fix will not be nessessary.
However, Screeming Eagle has a replacement compensating assembly that the MOCO uses as a replacement.
As he was telling me of the symptoms, I asked him if he was riding MY Trike.
I will be at my dealer ASAP.
From what info I got, If replacement is needed, it should be at n/c.
