ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Phu Cat2trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat2Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Results 1 to 6 of 6
Thread: Help with jacking up Freewheeler
    30+ Posts
    Jun 2016
    Bloomington il usa
    Default Help with jacking up Freewheeler
Size:  4.6 KB ok, I bought this lift from Harbor Freight and it fits under the Trike but when I lift it up all I am lifting is the front tire no matter where I place the jack. I tried tying the front wheel to the jack but that did not help. Now I did get the rear wheels off the ground maybe an inch but the jack wanted to tip back. Please give me some advice even if it is that I am doing something wrong. THANKS!!!!
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    The lift you are showing is for a 2 wheeler. The J & S jack for a trike is different, see below. It has a piece that engages against swing arm, to lift the bike level. Unfortunately that lift will not work, unless you add weight to the front. Even then I would be very hesitant about lifting my expensive trike with it.
    Nuc
    May 2016
    United States
    Default Rhino Ramps
    If you not changing a tire, buy a set of rhino ramps drive the trike up on them. Home Depot sells them so does Amazon, If you get a pair get the 12000 pound pair believe I paid 39.00.
    150+ Posts
    Jun 2015
    Yorktown, VA
    You can use that jack under the engine of your Freewheeler, but you will also need to support the rear with another small scissor jack. I just used my car jack with a piece of 2x4 on the axle. Between the two the trike is very stable up in the air and that's how I changed out my rear shocks that I got from DK Custom.
    Jun 2010
    Indianapolis, In.
    Rule #1. Never, ever buy anything from Horrible Fright, eeerrrr Harbor Freight!
    Rule #2. Never, ever trust your bike/trike to be safe on a cheap jack.
    J&S or Pit Bull, your choice.
    There will be many that say they have used various brands of these $100+or- jacks with no problems. They are very lucky, so far!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    Name:  pitbull trike adapter.jpg
    Bob
  1. Jacking a Tri-Glide
    By TG Bob in forum Harley Tri Glide
    Last Post: 05-15-2016, 02:56 PM
  2. Jacking up Champion S/A
    By Shimpy in forum Honda Trikes
    Last Post: 07-13-2015, 06:35 PM
  3. Jacking up
    By Cyg in forum Harley Tri Glide
    Last Post: 12-17-2014, 11:42 PM
  4. Jacking up TG ???
    By sandrooney in forum Harley Tri Glide
    Last Post: 07-24-2014, 10:07 PM
  5. Jacking it up
    By Josparkz in forum General Discussion
    Last Post: 09-01-2010, 11:34 PM
