Likes Likes:  9
Results 1 to 11 of 11
Thread: Jack I need help. Got a code?
    100+ Posts grandpawj's Avatar
    Jul 2015
    Lancing, TN USA
    Default Jack I need help. Got a code?
    While riding today I got a check engine light. It was intermittent. It would stay on for a while then go off. And...in a few minutes it would come back on. Engine seemed to be running fine. My cruise control quit working. When I got home and let it cool down I ran a code check on it. The only one that it showed was P0577. How do I systematically begin searching for the solution?
    Quote Originally Posted by grandpawj View Post
    Bad cruise switch would be my guess...Have you changed the bars or gripes lately.
    Jul 2015
    Lancing, TN USA
    Could be, I will have to check it out. But to answer you question, I haven't done anything to the grips (that I know of). Any idea what it would cost to get another switch?
    60 to75 Dollars, But i wouldn't run out and get one yet, It just might need a shot of contact spray...And i'm sure someone else will chime in with a little more info than i can give...
    This thread might help ... it has most of the codes
    http://www.triketalk.com/forum/threa...+trouble+codes
    Jul 2015
    Lancing, TN USA
    I am on my way to figuring it out. (I think) I have made it to table 4-53 "Cruise Inoperative Diagnostics" in the electrical shop manual. Right now I am trying to digest it all, tomorrow I will go outside and begin trying to follow the chart.
    Jul 2015
    Lancing, TN USA
    OK, now I have reduced the search to the rear brake switch circuit. The switch itself or a broken or skinned wire. More to come, I am sure.
    Name:  Cruise diagnostics.jpg
    4250+ Posts pcombe's Avatar
    Feb 2013
    casper,wy. usa
    Harley Trouble Codes
    The following procedure will instruct in retrieving and clearing ECM Diagnostic Trouble Codes and TSM/TSSM codes thru the Harley guage cluster as well as a list of codes.
    1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
    2- Push odometer reset button in & hold.
    3- Turn ignition switch to Ignition and release the odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
    4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
    5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
    P = ECM/ICM (Electronic Control Module) [EFI] / Ignition Control Module [Carbureted])
    S = TSM/TSSM (Turn Signal/ Security Module)
    SP = speedometer
    T = tachometer
    6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
    7 - Record the codes.
    8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
    NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
    9 – Press and release the odometer reset button to continue to the next module.
    10 – Turn Ignition switch to OFF.
    On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
    "No Rsp" (no response) will also appear if the run/off switch is in the off position when doing this procedure.
    HFSM = Hands Free Security Module
    TSM = Turn signal module
    Priority/DTC/Fault condition
    1. P0605 ECM FLASH Memory Error
    2. P0603 ECM EEPROM Memory Error
    3. U1300 ECM Serial Data Low
    4. U1301 ECM Serial Data High
    5. U1097 Loss of Speedometer Serial Data to ECM
    6. U1064 Loss of TSM/FSFM Serial Data to ECM
    7. P1003 System relay contacts open
    8. P1002 System Relay Coil High/Shorted
    9. P1001 System Relay Coil Open/Low
    10. P1004 System Relay Contacts Closed
    11. P1009 Incorrect Password
    12. P1010 Missing Password
    13. P06415 V+Vref 1 Out Of Range
    14. P06515 V+Vref 2 Out Of Range
    15. P0373 CKP Sensor Intermittent
    16. P0107 Map Sensor Open/Low
    17. P0108 Map Sensor High
    18. P0374 CKP Sensor Synch Error
    19. P1511 Throttle actuator control power management failure of throttle control actuator
    20. P1600 EFI Module Processor Internal Error
    21. P1270 TGS Validation Error
    22. P2107 EFI Module Processor Internal Fault
    23. P2101 throttle actuator control motor circuit range/performace error
    24. P2122 TGS1 Low/Open
    25. P2123 TGS1 High
    26. P2127 TGS2 Low/Open
    27. P2128 TGS2 High
    28. P2138 TGS Correlation Error (Twist grip sensor)
    29. P0120 TPS1 Range Error
    30. P0220 TPS2 Range Error
    31. P0122 TPS1 Low
    32. P0123 TPS2 High/Open
    33. P0222 TPS2 Low
    34. P0223 TPS2 High/Open
    35. P2135 TPS Correlation Error
    36. P2119 EFI Motor Throttle Body Range Performance
    37. P2100 EFI Motor Circuit Open
    38. P2101 EFI Motor Circuit Range Performance (Actuation Error)
    39. P2102 EFI Motor Circuit Low
    40. P2103 EFI Motor Circuit High
    41. P2176 EFI Closed Position Not Learned
    42. P1514 Air Flow Fault
    43. P2105 EFI Forced engine shutdown
    44. P1501 Jiffy Stand Sensor Low
    45. P1502 Jiffy Stand Sensor High
    46. P0572 Brake Switch Low
    47. P0117 ET Sensor Low
    48. P0118 ET Sensor High
    49. P0112I AT Voltage Low
    50. P0113I AT Voltage Open/High
    51. P1351 Front Ignition Coil Driver Open/Low
    52. P1354 Rear Ignition Coil Driver Open/Low
    53. P1352 Front Ignition Coil Driver High/Shorted
    54. P1355 Rear Ignition Coil Driver High/Shorted
    55. P1357 Front Cylinder Combustion Intermittent
    56. P1358 Rear Cylinder Combustion Intermittent
    57. P0261 Front Injector Open/Low
    58. P0263 Rear Injector Open/Low
    59. P0262 Front Injector High
    60. P0264 Rear Injector High
    61. P0562 Battery Voltage Low
    62. P0563 Battery Voltage High
    63. P0501 VSS Sensor Low
    64. P0502 VSS Sensor High/Open..
    65. P1356 Rear Cylinder No Combustion
    66. P1353 Front Cylnder No Combustion
    67. P0444 Purge Solenoid Open/Low
    68. P0445 Purge Solenoid High
    69. P1475 Exhaust Actuation Position Error
    70. P1477 Exhaust Actuator Open/Low
    71. P1478 Exhaust Actuator Shorted/High
    72. P0131 Front Oxygen Sensor Low
    73. P0151 Rear Oxygen Sensor Low
    74. P0132 Front Oxygen Sensor High
    75. P0152 Rear Oxygen Sensor High
    76. P0134 Front Oxygen Sensor Inactive
    77. P0154 Rear Oxygen Sensor Inactive.
    78. P1510 EFI Limited Performance Mode
    79. P1511 EFI Power Management Mode
    80. P1512 EFI Forced Idle Mode
    81. P0577 Cruise Control Input High
    1. U1300 Serial Data Low
    2. U1301 Serial Data High
    3. U1016 Loss of ECM Serial Data
    4. U1255 Serial Data Error
    5. B1142 Smart Security System Internal Fault
    6. B1135 Accelerometer Failed
    7. B1136(HFSM) Accelerometer Tip Test Error
    8. B1151 Bank Angle Sensor(BAS) Short to Ground
    9. B1152 Bank Angle Sensor(BAS) Short to Battery
    10. B1153 Bank Angle Sensor(BAS) High
    11. B1154 Clutch Switch Input Short to Ground
    12. B1155 Neutral Switch Input Short to Battery
    13. B1134 Starter Output High
    14. B1121(TSM) Left Turn Output Fault
    B1121(HFSM) Left Turn Output Open
    15. B1122(TSM) Right Turn Output Fault
    B1122(HFSM) Right Turn Output Open
    16. B1123(HFSM) Left Turn Output Short to Ground
    17. B1124(HFSM) Right Turn Output Short to Ground
    18. B1125(HFSM) Left Turn Output Short to Battery
    19. B1126(HFSM) Right Turn Output Short to Battery
    20. B1143(HFSM) Security Antenna Short to Ground
    21. B1144(HFSM) Security Antenna Short to Battery
    22. B1145(HFSM) Security Antenna Open
    23. B0563 Battery Voltage High.
    24. B1131(HFSM) Alarm Output Low
    25. B1132(HFSM) Alarm Output High
    26. B1141(TSM) Ignition Switch Low/Open
    B1141(HFSM) Ignition Switch Low/Open
    Feb 2013
    casper,wy. usa
    I have been having trouble with intermittent starts on my 1989 tour glide, It has been a long time in developing to the point where it wont start even with a full battery charge.
    I completely rebuilt my starter motor and starter solenoid, The contacts in the solenoid weren't looking to good.
    It is a much simpler operation rebuilding than you might imagine and kits are sold to do the job.
    I just replaced the old rocker switches for the start and shut down buttons on the right side handle bars as well as the starter relay which was actually good as it turns out.
    The culprits were the two wires that run to the starter.
    One comes off the starter relay and operates the exciter switch on the end plugging into the solenoid and the other comes off a main fuse that runs to the positive post on the starter its self.
    No visible damage to the wires but they ride under the starter motor instead of over it.
    I guess 28 years of vibration must have been to much for them? ( cheap stuff anyway huh? LOL.)
    Here is the other trick I pulled off after being 200 miles from home a couple weeks ago and had to get a push start.
    When rebuilding the solenoid I drilled a 5/16 " hole in the endcap of the removable solenoid cover, cut the head off a bolt and welded a thin washer to it and ground it smooth.
    Next I put an o ring over the bolt, inserted it through the cover and put a flat rubber washer on the outside over the bolt and added one of those concave washers that have rubber bonded to it at the hardware store to form a positive seal to keep water out.
    Next I cut an expansion spring to cover the rest of the bolt and put an acorn nut on the threads.
    It is a positve hold out even though it doesn't need one ( the starter plunger holds it out) it keeps it from flopping around.
    P.s. make sure there is a bit of play in the bolt so you are not holding the starter plunger in a position where it doesn't release after starting.
    So pay attention to how thick the washer is you welded onto the bolt and use a thin o ring on the inside of the solenoid cover.
    I drilled a hole and put a grommet on the outside chrome starter cover and now I can by pass the ignition switch its self and push in on the bolt and engage the starter plunger by hand.
    It even looks good!
    no more of this push start crap.
    As long as I have a reasonable charge in the battery it will start as long as I have the ignition switch turned on.
    Warning, it bypasses the ignition switch so it will operate without the key being turned on, Better have the trans. in neutral for a manual start ok?
    You can actually buy a switch such as this off the shelf for newer bikes for about $30.00 and these switches are mounted to the solenoid with three simple screws just by removing your old solenoid cover.
    The button simply engages the starter plunger by hand rather than electronically.
    The problem is there is a difference in starters beginning in 1990 and the don't make one for my 1989. GO figure?
  11. #10
    Jul 2015
    Lancing, TN USA
    Finally!! I replaced the rear brake light switch. No check engine light, no codes, and rear brake light comes on when pressing rear brake pedal and, and, and the cruise control works as it should.
  12. #11
    Feb 2013
    casper,wy. usa
    Something to keep in mind, Harley has had problems with these switches and wiring being to close to the exhaust and burning them out.
    they supposedly have a cure in a different switch.
    My experience?
    I had trouble every time I replaced a Harley switch with a Harley switch. it was burning out due to too much amperage draw from the brake system.
    CURE?
    I went to the auto parts store and bought a brake switch for a car, Screws right in, no more problem.
  1. F1 code in rain
    By Road Rider in forum Honda Trikes
    Last Post: 06-22-2016, 01:00 PM
  2. Help with engine code.
    By CaveManDave in forum VW Powered Trikes
    Last Post: 04-30-2016, 10:20 AM
  3. PPG Paint Code
    By onahog in forum Harley Trike Conversions
    Last Post: 03-28-2013, 11:12 PM
