AriNV4Pegasus1300Rider Safety Discuss...Maybe silly but serious question, s...
AriNV4cycle7447Rider Safety Discuss...Maybe silly but serious question, s...
AriNV4Jack KlarichRider Safety Discuss...Maybe silly but serious question, s...
AriNV4AriNVRider Safety Discuss...Maybe silly but serious question, s...
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
ken g9Old Road DogHarley Tri Glidereverse not working
Likes Likes:  8
Results 1 to 13 of 13
Thread: oil light came on, low range indicator appeared and the engine died.
    5+ Posts
    Dec 2016
    Atlanta
    Default oil light came on, low range indicator appeared and the engine died.
    Riding yesterday and entered a round-a-about at very slow speed. As I came through the final curve for my exit spoke, the oil light came on, low range indicator appeared and the engine died. I coasted to the exit and onto the shoulder and then far enough over and onto the grass. Turned everything off - sat for a minute and then restarted. All warning lights and indicators disappeared. Drove 2 minutes on to my brothers house and checked everything. All systems normal.
    Anyone else ever experience the "dashboard lighting up" and "engine shutoff" for no apparent reason? The only thing I can think of was the slope of the road plus the circular motion must have been enough to make the sensors report. Prior to my ride, the cold oil level was fine and range was 150 miles. I had ridden ~50 when this occurred. Welcome any thoughts or guidance. Should I visit my HD dealership?
    2500+ Posts Keystone's Avatar
    Jul 2010
    Minnesota
    I would certainly have it checked.
    BKMNI
    100,000+ miles of three wheel fun and counting!
    2015 Harley FLRT
    2018 Can-Am F3 Limited
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Harley Trouble Codes
    The following procedure will instruct in retrieving and clearing ECM Diagnostic Trouble Codes and TSM/TSSM codes through the Harley guage cluster as well as a list of codes.
    1- Turn Ignition switchto OFF & Run/Stop switch is to Run.
    2- Push odometer resetbutton in & hold.
    3- Turnignition switchto Ignition and release the odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
    4 - Push the odometer resetbutton once and you will seethe selection menu "PSSPt" with the first P flashing.
    5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer resetbutton one time. (from P to S to SP to t and back to P, etc.)
    P = ECM/ICM(Electronic Control Module)[EFI] /Ignition Control Module[Carbureted])
    S = TSM/TSSM (Turn Signal/ Security Module)
    SP = speedometer
    T = tachometer
    6 - To get the DTC within an area of diagnostics, push and hold the odometer resetbutton in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer resetbutton again to view additional codes if they exist.
    7 - Record the codes.
    8 - If DTC's are not to be cleared, Press and release the odometer resetbutton. Part number of module will be displayed.
    NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
    9 - Press and release the odometer reset button to continue to the next module.
    10 - Turn Ignition switch to OFF.
    On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
    "No Rsp" (no response) will also appear if the run/off switch is in the off position when doing this procedure.
    HFSM = Hands Free Security Module
    TSM = Turn signalmodule
    DTC’s are designated by a P,C,B or U
    P codes indicate issues monitored by ECM
    C codes indicate an issue with ABS
    B codes are set by Radio, Instruments and BCM
    U codes indicate a communication problems with the modules
    Fault Code Abbreviation List
    ABS – Anti-Lock Braking System
    ACR – Automatic Compression Release
    AFR – Air Fuel Ratio
    AIS – Active Intake Solenoid
    ATS – Air Temperature Sensor
    BAS – Bank Angle Sensor
    BCM – Body Control Module
    CAN – Controller Area Network
    CCM – Cruise Control Module
    CKP – Crank Position Sensor
    DLC – Datalink Connector
    DTC – Diagnostic Trouble Codes
    ECM – Electronic Control Module
    ECT – Engine Coolant Temperature
    ECU – Electronic Control Unit
    EFI – Electronic Fuel Injection
    EFP – Electronic Fuel Pump
    ET – Engine Temperature sensor
    FI – Fuel Injectors
    FPR – Fuel Pressure regulator
    H-DSSS – Harley-Davidson Smart Security System
    HCU – Hydraulic Control Unit, ABS
    [/stag_one_half][stag_one_half_last] HFSM – Hands Free Security Module
    HO2S – Heated Oxygen Sensor
    IAC – Idle Air Control actuator
    IAT – Intake Air Temperature sensor
    ICM – Ignition Control Module
    IMAP – MAP + IAT in one unit
    ISS – Ion Sensing System
    JSS – Jiffy Stand Sensor
    LHCM – Left Hand Control Module
    MAP – Manifold Absolute Pressure Sensor
    MHR – Right Hand Control Module
    RCM – Reverse Control Module
    TCA – Throttle Control Actuator
    TGS – Twist Grip Sensor
    TMAP – Intake Air Temperature / Manifold Absolute Pressure equipment
    TPS – Throttle Position Sensor
    TSM / TSSM – (Turn Signal / Turn Signal Security Module)
    VE – Volume Efficiency
    VIN – Vehicle identification number
    VSS – Vehicle Speed ​​Sensor
    WSS – Wheel Speed ​​Sensor
    P0031 Front HO2S low/open
    P0032 Front HO2S shorted/high
    P0051 Rear HO2S low/open
    P0052 Rear HO2S shorted/high
    P0072 AAT sensor low
    P0073 AAT sensor high/open
    P0107 MAP sensor failed low/open
    P0107 Map Sensor Open/Low
    P0108 MAP sensor failed high/open port
    P0112 IAT Voltage Low
    P0113 IAT Voltage Open/High
    P0117 ET Sensor Low
    P0118 ET Sensor High
    P0120 TPS1 Range Error
    P0122 TPS1 Low
    P0123 TPS2 High/Open
    P0131 Front Oxygen Sensor Low / Engine Lean
    P0132 Front Oxygen Sensor High / Engine Rich
    P0134 Front Oxygen Sensor Inactive
    P0151 Rear Oxygen Sensor Low / Engine Lean
    P0152 Rear Oxygen Sensor High / Engine Rich
    P0154 Rear Oxygen Sensor Inactive
    P0220 TPS2 Range Error
    P0222 TPS2 Low/Open
    P0223 TPS2 High/Open
    P0261 Front Injector Open/Low
    P0262 Front Injector High
    P0263 Rear Injector Open/Low
    P0264 Rear Injector High
    P0265 Rear injector shorted high
    P0371 CKP sensor wrong number of pulses
    P0373 CKP Sensor Intermittent
    P0374 CKP Sensor Synch Error
    P0444 Purge Solenoid Open/Low
    P0445 Purge Solenoid High
    P0501 VSS Sensor Low
    P0502 VSS Sensor High/Open
    P0503 VSS failed high
    P0505 Idle speed control unstable
    P0562 Battery/ECM Voltage Low
    P0563 Battery/ECM Voltage High
    P0572 Brake Switch Low
    P0577 Cruise Control Input High
    P0603 ECM EEPROM Memory Error
    P0605 ECM FLASH Memory Error
    P0641 5 Volt Reference 1 Out of Range
    P0651 5 Volt Reference 2 Out of Range
    P0691 Fan/cooling relay output low/open
    P0692 Fan/cooling relay output high
    P1001 System Relay Coil Open/Low
    P1002 System Relay Coil High/Shorted
    P1003 System relay contacts open
    P1004 System Relay Contacts Closed
    P1009 VTD Disabled Fuel Due to Incorrect Password
    P1010 Missing Password
    P1017 ET indicates overheating
    P1019 ECT Difference (high temp)
    P1270 TGS 2 A/D Validation Error
    P1351 Front Ignition Coil Driver Open/Low
    P1352 Front Ignition Coil Driver High/Shorted
    P1353 Front Cylnder No Combustion
    P1354 Rear Ignition Coil Driver Open/Low
    P1355 Rear Ignition Coil Driver High/Shorted
    P1356 Rear Cylinder No Combustion
    P1357 Front Cylinder Combustion Intermittent
    P1358 Rear Cylinder Combustion Intermittent
    P1475 Exhaust Actuation Position Error
    P1477 Exhaust Actuator Open/Low
    P1478 Exhaust Actuator Shorted/High
    P1501 Jiffy Stand Sensor Low
    P1502 Jiffy Stand Sensor High
    P1510 EFI Limited Performance Mode
    P1511 EFI Power Management Mode
    P1512 EFI Forced Idle Mode
    P1514 ETC Air Flow Fault/Error
    P1600 EFI Module Processor Internal Error / Watchdog Error
    P1608 Loss of continuous battery
    P1655 ACR solenoid low/open
    P1656 ACR solenoid shorted high
    P1691 Cooling fan left low/open
    P1692 Cooling fan left shorted high
    P1693 Cooling fan right low/open
    P1694 Cooling fan right shorted high
    P2100 EFI Motor Circuit Open
    P2101 EFI Motor Circuit Range Performance (Actuation Error)
    P2102 EFI Motor Circuit Low
    P2103 EFI Motor Circuit High
    P2105 EFI Forced engine shutdown
    P2107 EFI Module Processor Internal Fault
    P2119 EFI Motor Throttle Body RangePerformance
    P2122 TGS1 Low/Open
    P2123 TGS1 High
    P2127 TGS2 Low/Open
    P2128 TGS2 High
    P2135 TPS Correlation Error
    P2138 TGS Correlation Error (Twist grip sensor)
    P2176 EFI Closed Position Not Learned
    P2184 ECT sensor low
    P2185 ECT sensor high
    P2300 Ignition coil driver low/open (front)
    P2301 Ignition coil driver shorted high (front)
    P2303 Ignition coil driver low/open (rear)
    P2304 Ignition coil driver shorted high (rear)
    Have a look here first
    IMO U want to know what ur ECM knows
    It will tell U about codes and part numbers affected by the codes if any are present
    Next, I would run the bike warm with a box fan and a thermometer
    With a GOOD oil pressure master gauge in line near the oil filter to eliminate the { NEVER IMO oil low pressure idiot light}
    HD lights and gauges are NO FING good IMO
    If this is a TC oil pumps and TOO much crank run out is the first thing to check
    I do NOT want to scare ya, but HD runs low pressure but HIGH volume { the engines will and do run good with what appears to be very low oil pressure} ass uming what I know to be true
    THESE ARE JMO Good Luck
    5+ Posts
    Dec 2016
    Atlanta
    Wow - thanks very much - this is a ton of information. Truly appreciate it.
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by marnie View Post
    Were you low on gas? Going around a left corner will move the gas to the opposite side of the fuel pick up...when low, this can cause the engine to stutter or die.
    As soon as things are back level/straight, the fuel is there for the pick up.
    If it's an M8, the oil could be a similar issue.
    If not low on gas I would have it checked on the dying....on the oil, I would have it checked either way.
    www.DKCustom.com
  6. #6
    50+ Posts
    Jan 2015
    Millersburg, Pa
    Shot in the dark here but I think there is a tip over/roll over sensor on these. If its not fastened down correctly in a turn it could possible break the circuit and shut down the motor. If i remember correctly it is clipped to the top of the battery box.
  7. #7
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Look at this diagram Number 12 is the BCM, Seems to me the tip over switch is in here now. I could be wrong but the can bus electrical did change some , Dunno 4 sure but if U run the system check thru ur speedo it should {SHOULD} spit out a code OR the word could show in the odometer window. JMO
  8. #8
    1000+ Posts
    Aug 2012
    Pendleton, Oregon USA
    Default Failure
    Same thing happened to the Wife's one year while traveling, except it didn't die.
    After pulling off the hi way we stopped it then restarted it after a couple of minutes-all was normal and we have never had it happen again - figured it was a fluke or elect. spike.
    She now has just turned 51 thou. miles - LOVE OUR TRIKES!
  9. #9
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    Actually it may be a bad BAS (Bank Angle Sensor). This sensor is used for turn signals and tip overs.
    Bob
    Name:  Bank Angle Sensor.jpg
  10. #10
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Seems to me the BAS is now in the ECm like #10 above?
  11. #11
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    BANK ANGLE SENSOR SWITCH KIT
    J045392008-09-19
    GENERAL
    Kit Number
    88115-09
    Models
    This kit must be installed on 2009 and later FL Touring Models being fitted with a TLE or TLE-Ultra Sidecar Kit.
    This kit can also be used as a replacement on those same models already equipped with a TLE or TLE-Ultra Sidecar Kit.
    Early 2009 models may not have the correct battery box for the sidecar installation. The battery box must have the inscription "Sidecar Tip Sensor" molded into the right front side of the battery box.
    Additional Parts Required
    Early 2009 FL Touring models will require the Battery Tray Kit (66281-09A) to use the Bank Angle Sensor when installing the TLE or TLE-Ultra Sidecar Kit.
    Following installation of the Bank Angle Sensor Switch, the DIGITAL TECHNICIAN® II and Data Link must be used to program the security module (TSM/TSSM/HFSM) for sidecar (with gravity activated bank angle sensor) application.
    WARNING
    Failure to properly configure the TSM/TSSM/HFSM can cause engine to shutdown which could lead to loss of control and death or serious injury. (00581b)
    If the security module is not configured and calibrated after the sidecar and bank angle sensor has been installed, the motorcycle will operate in solo mode, and the engine may shut down when the vehicle takes a sharp corner. Additionally, the turn signals may cancel prematurely when navigating rough conditions (i.e. potholes, bumps, etc.).
    Kit Contents
    See Figure 2 and Table 1.
    INSTALLATION
    NOTE
    If equipped with the optional "Harley-Davidson Smart Security System", verify that the security status lamp in the speedometer face is not flashing (security system disarmed) before proceeding.
    WARNING
    To prevent accidental vehicle start-up, which could cause death or serious injury, remove main fuse before proceeding. (00251b)
    1 Battery tray
    2 Bank angle sensor (sidecar tip sensor) location
    Figure 1. Battery Tray for Bank Angle Sensor
    1. See Figure 1. Remove the right-side cover. If the battery tray (1) does not have the inscription "Sidecar Tip Sensor" as shown in Figure 1 you must purchase and install the Battery Tray Kit (66281-09A) before installing the sidecar.
    2. Remove the left-side saddlebag according to the instructions in the Service Manual. Remove the left-side cover and disconnect the main fuse.
    3. Where you removed the right-side cover, disconnect the gray twelve-way socket housing from the security module. Plug it into the twelve-way pin housing on the bank angle sensor harness from the kit.
    4. Plug the gray twelve-way socket housing from the bank angle sensor harness into the security module.
    5. Plug the three-way socket housing from the bank angle sensor harness into the bank angle sensor switch.
    6. Install the bank angle sensor switch to the right front corner of the battery tray with the screw from the kit.
    7. Refer to the Service Manual and follow the instructions given to install the right-side cover, tucking any excess wires under the cover. Install the main fuse, left-side cover and saddlebag per the instructions in the Service Manual.
    NOTE
    If the Bank Angle Switch is actuated by tilting, the ignition circuit is disabled. The Bank Angle Switch may be reset by turning the ignition switch OFF for five seconds, then ON.
    Whenever the sidecar is removed, the Bank Angle Switch kit should be removed and the security module should be switched back to solo vehicle operation by a Harley-Davidson dealer.
    Instructions for installing or removing the Bank Angle Switch Kit, and procedures for configuring the security module are given in the Sidecar Service Manual, Part Number 99485-xx.
    SERVICE PARTS
    Figure 2. Service Parts, Bank Angle Sensor Switch Kit
    Table 1. Service Parts Table
    Item
    Description (Quantity)
    Part Number
    Switch, bank angle sensor
    32495-98
    2
    Harness, bank angle sensor
    88104-09
    3
    Screw, self-tapping
    4790
    Items mentioned in text, but not included in kit:
    A
    Battery tray
    OOPS, this may help
  12. #12
    Sep 2016
    Springfield, Mass. USA
    J045392008-09-19
    GENERAL
    Kit Number
    88115-09
    Models
    WARNING
    Kit Contents
    INSTALLATION
    NOTE
    WARNING
    1 Battery tray
    NOTE
    SERVICE PARTS
    Item
    Part Number
    32495-98
    2
    88104-09
    3
    Screw, self-tapping
    4790
    A
    Battery tray
    OOPS, this may help
    How did you make out with this problem??
  13. #13
    1000+ Posts screwball's Avatar
    Apr 2011
    Santa Clarita, SoCa & Bullhead City, Az
    IF I read your post correctly, the oil pressure light came on BEFORE the gas light and the engine died. Unless you were going around the traffic circle REALLY FAST I'd doubt it if it is the tilt sensor. Low oil pressure isn't something you want to screw with. You didn't say if you had a warranty or what year your trike is. Under warranty, get it to a dealer..... if it were mine and out of warranty I'd take it to a dealer anyway.
    http://www.triketalk.com/forum/custo...epic4494_1.gif
    Why 3 wheels?
    because 2 isn't enough and 4 is too many
    We are really Steve & Vesta Brown
    Her: 2014 Tri-Glide Me: 2015 Freewheeler
    Vietnam Vet 1967-68 U.S. Air Force
  1. The 'Check Engine' Light Means So Much More These Days...
    By Jerry/MD in forum Harley Tri Glide
    Last Post: 04-03-2017, 12:11 PM
  2. Engine light
    By hisst in forum Honda Trikes
    Last Post: 02-02-2015, 07:05 AM
  3. Check engine light
    By Trapper54 in forum Harley Trike Conversions
    Last Post: 06-06-2014, 08:28 AM
