Likes Likes:  1
Results 1 to 11 of 11
Thread: Moly or bearing grease for U-Joints???
    500+ Posts
    Feb 2008
    Planet Earth, Alpha Quadrant
    Default Moly or bearing grease for U-Joints???
    Do any of you that use MOLY grease for your driveshaft splines, also use the same "Moly" grease for your U-joints??
    Or do you use a lighter grease for the U-joints?
    Rake...
    Never had it....
    Never will...
    550+ Posts Mick's Avatar
    Feb 2008
    Midwest
    Heres what I use on my driveshaft joints. Been using if for years. On the driveshaft splines I use what Honda recommends.
    2500+ Posts Gold Rush's Avatar
    May 2011
    San Angelo
    Quote Originally Posted by cjmitch View Post
    NOPE... I use LUCAS "Red-N-Tacky" on the U-Joints.....
    Jerry "Gold Rush" (aka: "SPOOK") San Angelo, TX
    2015 GL1800/Roadsmith HTS1800
    TOI - IBA #23804 (SS1K & BB1.5K)
    I'm like an old race horse..... I can still run the race -- Just ache more at the finish line and need more rest between outings.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Schaffer waterproof sticky stuff. Or any Marine grease. My quad has a bizilion grease fittings, so waterproofing is a must.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Like Frank....Marine Grease In my ATV, And Side-Bys....
    2019 Tri-Glide.......
  6. #6
    JustWings.com
    Tech Contributor
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    This can be confusing, but it appears Hondas' Service Manuals use a generic page when it comes to chemicals. The chemical page is found behind the Table of Context page. It shows 2 Moly's a paste and a grease. However, the only MOLY used on a GL1800 is MolyKote Br-2 plus. I'm sure very few readers have it. Many might have tubes of Moly 60 sold by Honda dealers and shown on their chemical page, but, according to Honda's Service manual, that grease is not intended to be used anywhere on a GL1800. Finding a page where they actual call for it's use has thus far not been found.
    I use MolyKote Br-2 plus as Honda calls for it in their service manual. I use it when doing transmission repair lubing main, and rod bearings, on some internal and external reverse parts, and lubing drive shaft splines.
    On the chemical page where Moly 60 is shown, they also show MolyKote G-n2 as a substitute. If I recall G-n2 is a lube intended for plastic and not metal. Moly 60 could be the same, so unless the tube says something else, its best to not confuse Moly 60 as a metal lubericant. I do have a tube of Moly 60 paste but have never read the tube or used it.
    As for U-joint grease. Back in the 70's grease guns were full of common grease used to lube suspension parts. The same guns were used to grease u-joints. However, now it's more confusing. There are several choices and often their containers have warning about not mixing them. So be cautious.
    The rule of thumb I was always taught in all my auto shop courses was ... never use a chemical unless it can be justified.
    Below is a picture of how I order in my MolyKote Br-2. I have to order mine off the internet. I've never found it on a shelf anywhere in my greater city area (Tampa). This city is to small for such and is also why very few will have this grease.
    Please keep in mind that anytime I share or give advice about a motorcycle, unless I state otherwise, I am always referring to GL1800's and no other.
  7. #7
    500+ Posts
    Feb 2008
    ok now im just as confsed as i was...
    I use valoline moly for the splines and Mobil 1 synthetic for the U-joints.
    I think i better call motortrike
    Rake...
    Never had it....
    Never will...
  8. #8
    Meme Master
    Jan 2014
    Farmington, NH USA
    My worldly experience has taught me that any grease on a regular basis is better than none!
    If one wants to extend the greasing interval beyond the original manufacturer's spec, synthetic is the only way to go. There are many other positive reasons to use a synthetic, but time nor space allow the full discussion.
    If one is "religious" in keeping to the manufacturer's lube schedule, a moly/dino/conventional grease probably works just as well...
  9. #9
    JustWings.com
    Tech Contributor
    May 2016
    Opps ... sorry ... I was living in the 2-whld world and forgot this is a trike forum. When it comes to drive shafts on a trike, the trike manufacture is the ones to consult for proper lubing of their drive shaft. Sometimes that info is printed in a trike's Owner's Manual.
  10. #10
    500+ Posts
    Feb 2008
    Quote Originally Posted by GoldWingrGreg View Post
    Correct... I called Motortrike, and they say automotive MOLY for splines AND in the u-joints.
    Mine is coming off this weekend for regreasing!!!
    Rake...
    Never had it....
    Never will...
  11. #11
    JustWings.com
    Tech Contributor
    May 2016
    Glad to hear you are inspecting and lubing as needed. When you check the slip joint splines, if you find something like this, repair is needed. Be sure to clean them for a good inspection, and then lube them with the Moly MotorTrike calls for.
  1. Steering Head Bearing Grease
    By Roadie in forum Yamaha Trikes
    Last Post: 03-11-2015, 09:01 AM
  2. Grease
    By dogman513 in forum Lehman Trike
    Last Post: 10-09-2014, 07:26 PM
  3. Grease U Joints???
    By QuapaBrave in forum Honda Trikes
    Last Post: 10-31-2013, 06:06 AM
