Likes Likes:  8
Results 1 to 18 of 18
Thread: Engine Oil
    5+ Posts
    Jul 2017
    Beverly Hills, FL
    Smile Engine Oil
    What is your oil of choice for your Goldwing? Why?
    Jun 2008
    Lovington, NM, U.S.A.
    Well, when I had my GL1500 I used Honda GN-4 with an OEM filter and new crush washer. I just followed what Honda recommended, as I didn't like my Wing getting damaged or having problems.
    Retired trike builder
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    My choice is Chevron Delo 400 LE. I used to use Shell Rotella on my GL1500 because it was supposed to help with the clunky shifts that was experienced using standard Honda oil. It did help but tben I saw where some had started using the Delo instead of the Rotella and said it made shifting even smoother. I tried it and it gave me nice smooth shifts. I have continued using it after purchasing my GL1800 with the same results. I do still use the OEM filter as I feel it is the best choice. I usually buy the Delo in 3 gallon packs at Costco when it goes on sale. Sale price is usually around $28 for the 3 gallon case.
    1500+ Posts Dockem's Avatar
    Jul 2011
    Cville, IN / Leesburg, FL
    Full synthetic for easier shifting. I've been using Mobil 1 10w-40 for my GL1800 Trike.
    When I had my 1500 Valkyrie I/S, I used Mobil 1 10w-50 with good shifting results also.
    YMMV, use what you and your bike/trike favor. Lot's of good products out there, but I would use a name brand, just my bias.
    Asking what oil to use is like asking "what's your favorite color?"
    The human race has only one really effective weapon, and that is laughter. - Mark Twain
    People who drink light 'beer' don't like the taste of beer; they just like to pee alot. - Capital Brewery, Middleton, WI
    TOI #01585 VRCC #506 Iron Butt #10256 NRA Life Member
    JustWings.com
    Tech Contributor
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Honda's GN-4 ... it's their conventional oil. Here is why I'm not in favor of synthetics. In the friction zone, synthetics are known to cause more clutch slippage, and occasionally when doing tranny repair, I come across blued clutch discs from excessive heat. I was always thinking it was the rider being in the friction zone to long ... 2-whl slow races, or a trike rider feathering at a light on a hill to keep from rolling back, etc. However, I'm now in belief it's because the rider uses synthetic oil, and coupled with their clutching habits, and/or where they ride, it is not a good choice for them. Without knowing it, other may fall into this category.
    Whatever oil you choose, make sure it abides to all suggestions and requirements in your Owner's Manual. Suggestions should be taken as a requirement. For example, if the Owner's Manual suggests to use either 10w-30, or 40, that means only use 10w-30 or 10w-40. If it suggests to only use m/c specific oil, only use m/c specific oil.
    Please keep in mind that anytime I share or give advice about a motorcycle, unless I state otherwise, I am always referring to GL1800's and no other.
  6. #6
    500+ Posts Konrad's Avatar
    Nov 2010
    La Grange, KY
    Default Snthetic
    Quote Originally Posted by RedGW08 View Post
    2006 GL 1800. In the last 10 years I've put on 55,000+ miles, a couple of times cross-country. Have always used Shell Rotella. I like the price and my bike likes the oil.
    Some like strawberry and others prefer chocolate.
  7. #7
    100+ Posts wingit's Avatar
    Jul 2015
    Richmond Mn.
    Cool
    Delo 400LE for me too. My dodge diesel used 2 qts in 4000 miles every change on Rotella 15/40 for 8 years.Tried Delo 15/40 and using no oil last 3 oil changes.
    It claims an iso syn ? process similar to synthetic
    Shifting seems smoother and stays the same to the next change at 3 to 4k miles .I have more friends and my hair stopped falling out ..What a mysterious world God has created
  8. #8
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Castrol 10-40 and 20-50 in warm weather. Been using it in 9 Wings for over 30 yrs with no issues.
  9. #9
    Dec 2014
    Grand Junction, Co. USA
    I always use what the manufacturer recommends ... but you have to love a new oil thread.
  10. #10
    5+ Posts
    Jul 2017
    columbia tennessee USA
    I use Delo 400 15w40 never have any problems.
  11. #11
    10+ Posts
    May 2017
    Ellicott City, MD USA
    Default Valkyrie Oil
    So, I presume no slippery clutch problems? (I used Mobil 1 15-50 for my first 21k but my trike builder said real motorcycle oil has additives for oilbath clutches)??? I'm confused, now.
    Quote Originally Posted by Dockem View Post
  12. #12
    Jun 2008
    Do not use any oil that says, "Friction Reducing", "Contains Moly", "Energy Conserving". Must read, "Safe for wet clutches".
    Must also be JASO.
  13. #13
    1000+ Posts mhgoldwing's Avatar
    Mar 2011
    mountain home,ar. USA
    Since '11 when I bought my used '06 Wing I've put on 60K miles. Triked it at 7,500 miles and began using Rotella T6. Then went to Motul. Used OEM filters always. I got tired of reading oil threads and worrying about it so I returned to Honda HP4S with OEM oil filter and new crush washer at every change which occurs at 6,000 mile intervals. Now I sleep better and only check out these oil threads periodically to appreciate why I quit reading them.
    Wing with Roadsmith kit, Traxxion Ak20 cartridges and Accuride System.
    07 ST 1300 for two-wheeled fun!
  14. #14
    Apr 2010
    Shenandoah Valley of Virginia
    Chevron Delo 400 LE 15W40 .... smoother shifting for one reason .....
  15. #15
    JustWings.com
    Tech Contributor
    May 2016
    Thumbs up
    Quote Originally Posted by trike lady View Post
    That says it all ... "why" "problem," and "solution." Honda makes it so easy for an owner to do proper maintenance by supplying the exact products a GL1800 needs.
  16. #16
    1+ Posts
    May 2016
    Bandera
    Default Gl 1500 oil
    I have been using NAPA 14-40 pure synthetic in my 1998 Gl 1500 SE with no problems. Shifts are smoother and the bike seems to run a little cooler. Here in South Texas with 100 plus temps this time of year I think the 15-40 is better than the recommended weight.
  17. #17
    5250+ Posts Pegasus1300's Avatar
    Oct 2011
    Spring City,Utah, USA
    I used Shell Rotella 15-40 mineral oil in my 1990 SE. Shifted well, ran smooth and never used any. Also cheap at WalMart so you can find it everywhere. I would change it out every 3000 mi. I started that when bikes started to come with oil filters. Before filters it was every 1000 mi. or once a month.
    Happy TRAils/NSD
    Paul
  18. #18
    600+ Posts keepinon's Avatar
    Dec 2011
    New Caney, Tx
    All good points on MC oils. However, my shop manual says use motor oils that meet or exceed SF or SG API certification. I do go the extra step to insure that it meets JASO standards, as well.
    Another consideration is the weight of the oil. I know locally, if you take your GW to the dealer and ask for an oil/filter change, you'll get 10w-30 GN4. They say it's because you'll get better fuel mileage. But mother Honda's chart on oils, shows heavier oil for use at temps above 90*F, which it is here for much of the year.
    ​2007 Goldwing w/MT Adventure conversion
    IBA: 65855 SS1000, National Parks Tour, Master Traveler Award
    https://www.dosgreengoes.blogspot.com
  1. Rear-engine vs. mid-engine...pro's/con's?
    By Gruuve in forum General Discussion
    Last Post: 02-08-2019, 04:10 PM
  2. HD's new engine
    By Mykneesbehurtin in forum Harley Tri Glide
    Last Post: 07-29-2016, 08:38 AM
  3. vw engine ser# ID
    By bluedog in forum VW Powered Trikes
    Last Post: 07-14-2013, 08:17 AM
  4. New engine?
    By molinoman in forum Stallion Trikes
    Last Post: 05-01-2013, 09:14 PM
  5. vw engine/hp
    By grigglybob in forum General Discussion
    Last Post: 03-06-2013, 03:26 PM
