Speed Bleeders
Likes Likes:  9
Results 1 to 20 of 20
Thread: Right front brake handle
    100+ Posts
    Jun 2015
    Stafford, Va
    Default Right front brake handle
    My right brake handle has a little play, but I noticed it's squeaking a bit. Thoughts or ideas?
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by DonC View Post
    A shot of spray lubricant will take care of the squeak...How much is a little play, and did it just get loose...
    2019 Tri-Glide.......
    100+ Posts
    Jun 2015
    Stafford, Va
    When I say loose or slight it's the nay when I go to engage. But probably would not have noticed if not for squeak.
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Look at #10, it is a bushing for your lever (both levers have 1)
    Over time they do wear, the levers both need a bit of slop thru the bushings, or they would bind or snap off. Use some spray lube each oil change, and put a dab of white grease in the front of the lever, it is kind of tricky, I use a long swab.
    850+ Posts jc1300's Avatar
    Apr 2015
    Clarksville, TN, USA Via North of Chicago
    How many miles on the bike?
    jc
  6. DKCustoms postbit
  7. #6
    100+ Posts
    Jun 2015
    Stafford, Va
    Quote Originally Posted by jc1300 View Post
    jc
    7,000
  8. #7
    100+ Posts
    Jun 2015
    Stafford, Va
    What about some spray silicone lubricant? If not I'll have to pick up some white grease 👊😎👍
  9. #8
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Yep give it a squirt.....Can't hurt.......Wd40..
  10. #9
    Apr 2015
    7,000
    Man ~ Hard to believe that the bushings etc. have worn enough to cause a squeak. I would lean more to the cable itself being the culprit. That said - A little Oil / DW 40 etc. around the movable thingy's and maybe then a drop or two down the cable. But gonna be real curious what you find.
    jc
  11. #10
    Dec 2013
    Clarion PA USA
    Thumbs up Silicone for me
    WD 40 lets see Water Displacement 40 th formula 90% Kerosene no thank you it is good stuff for what it is intended. However there are better products available for brake levers than WD 40. Everyone grabs it because we all have it on our shelves in the garage just sayin... ride safe Fred
  12. #11
    70+ Posts zbear's Avatar
    Aug 2013
    CedarRapids,Iowa USA
    jc
    I guess I never knew the brake master cylinder had a cable.
    2013 Anniversary Trike with upcoming upgrades#1344 of 1450. 1994 FLHTC, painted with '57 tropical turquoise. Bored, Cammed, SU carb. "Old Whore" 600 watt Sony stereo.
  13. #12
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    I wonder if there is a chance the bushing got left out on assembly? Might check.
  14. #13
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by zbear View Post
    The Triglides and Freewheelers do not
    Both are Hydaulic
  15. #14
    Apr 2015
    LOL - Old people and old terms! Plunger ~ Man - I am on a roll lately!!
  16. #15
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Gorilla View Post
    Would not be surprised
  17. DKCustoms postbit
  18. #16
    100+ Posts
    Jun 2015
    Stafford, Va
    According to my Manuel. There is no bushing
  19. #17
    100+ Posts
    Jun 2015
    Stafford, Va
    Default Push rod/dust boot
    It was the pushrod/dustboot. Number 9.
    Sprayed some silicone lubricant up there. Right as rain 😎👍👊
    thanks for input fellows 👊
  20. #18
    Apr 2015
    Plunger / Pushrod / That has to count for like an almost! So sad.....jc
  21. #19
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Post 4 shows the bushing
    Back as far as 1990 the baggers used some sort of bushing to ease the levers and prevent wear
    JM Observations
    {This may or not be a disclaimer}
  22. #20
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    The bushing is pressed into # 7........
  1. Front brake modification
    By mhgoldwing in forum Honda Trikes
    Last Post: 03-24-2016, 06:21 AM
  2. front brake
    By howardg in forum Honda Trikes
    Last Post: 07-02-2015, 02:35 PM
  3. New Front Tire - Handle Bar Vibrations at 70 mph
    By bassfisher in forum Honda Trikes
    Last Post: 05-12-2014, 02:55 PM
  4. front brake pad mileage
    By phil1945 in forum Honda Trikes
    Last Post: 12-23-2013, 07:09 PM
  5. Parking Brake Handle
    By lboos in forum Harley Trike Conversions
    Last Post: 03-03-2013, 12:09 PM
