Likes Likes:  5
Results 1 to 11 of 11
Thread: Trike won't crank while in gear
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Mitchell, Indiana, USA
    Default Trike won't crank while in gear
    On a 2017 with ~7000 miles on it with the clutch pulled in and either or both brakes applied.
    Does fine in neutral but it won't crank while in gear.
    It worked a while back then I started noticing it wouldn't work occasionally and now it seems to be all the time.
    Any ideas.
    I need to take it in sometime to get the Front Fender tip light replaced so I will have them look at it then but was wondering if I was missing something.
    Bob
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Press the rear brake very hard and it will start,its a safety item.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    I noticed on my 17......Unless I'm fully pressing/hard on the brake pedal it won't start in gear..
    2019 Tri-Glide.......
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Default Just tried that
    Quote Originally Posted by Mykneesbehurtin View Post
    Pressed it as hard as I could and tried it.
    Did both front and back as hard as I could still didn't work.
    Bob
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Does ur cruise work right? I ask because this is also tied to your brake switch, being a 17 u r covered by warranty. This happened to my 15 Freewheeler by a stupo service manager. I had it in for a leaky rr shock, this NEW stupo came out and jumped on the rear brake pedal asking me if I was sure it wasnt a brake fluid leak. I was so pissed,
    I left and called the OWNER who took care of it the next day
    HD has had some problems ringing out some of the early 17s as well as the older 15s, Good Luck and check back in
  6. DKCustoms postbit
  7. #6
    80+ Posts wiltat2's Avatar
    Apr 2011
    Yuma, Az.
    I have had the same problem with my 17 Tri-Glide. There is some sort of electrical switch in the left hand grip that has been replaced two or three times by the dealer for this exact same problem. Initially it happens intermittently then just does not work, have to be in neutral.
    On the work order it indicates: 71500135A SWITCHPACK,HC,LH,AUDIO&CR Quantity 1 Price 215.26
    LABOR Job Code 6165
    Work Description Bike will not start in gear.
  8. #7
    450+ Posts MB1953's Avatar
    May 2014
    Peru, IN USA
    Had the same thing happen on my '14... two dealers told me I was crazy, but one actually looked at their service bulletins, ordered the left switch pack, and when it came in a week later, replaced it in about 15 minutes. No charge, warranty work.
    2017 TriGlide Vivid Black - DK Outlaw AC, Fullsac performance baffles, PowerVision from DK, Love Jugs Mighty Mites from Papa Zook, HD Black Reach Bars, all kinds of BLACK stuff... Hi, my name is Mark and I used to be a chromeaholic!
    was - 2014 TriGlide Vivid Black - DK Custom Lift, 2" tank lift, DK Dual Cool, DK Discrete breather, Wards Parts Werks FCS, HD Reach Bars, all kinds of shiny stuff!
  9. #8
    250+ Posts
    Nov 2012
    Bradenton, FL.
    I installed the Get A Grip Magnum HD Grips and had the same problem.
    2019 Red and Silver Tri Glide
  10. #9
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    I have the Oberon adjustable clutch lever, And if i use the #1 position it won't activate the start switch on the clutch lever when the trans is in gear...But thats not a problem for me, I only use the #2 position....Is seems that' The switch is sensitive for its contact point...
    And the proper brake pedal pressure, So i can see how those switches can go bad...
    Even my Rhino won't start in gear without stepping hard on the foot brake...I hate those so called safety gismos....Interesting though my Polars ATV will start in gear with out using the brake...
  11. #10
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    As noted, a switch can go bad and even though the clutch is pulled in and the brake is on, the BCM does not know it and it won't start.
    Have had that happen to me several times on different bikes & trikes. Took it in, switch replaced, and all was well.
    www.DKCustom.com
  12. #11
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Default Scheduled a trip to the Shop
    Scheduled it in the shop for next Friday.
    They will check this out as well as the Front Fender Light and Flash the computer to have the passing lights on all the time.
    Should have it back on Saturday if they don't have to order any parts.
    Thanks for all the replies
    Bob
  1. Stallion Wouldn't Crank
    By Dean H in forum Stallion Trikes
    Last Post: 06-11-2015, 09:30 PM
  2. crank sensor
    By lasso in forum Harley Trike Conversions
    Last Post: 09-10-2014, 07:35 AM
  3. starter gear teeth 12v 1600 vw of the gear
    By bluedog in forum VW Powered Trikes
    Last Post: 07-24-2013, 04:22 PM
