Nice ... Do you feel like you see better?
When night riding, she can't help but see some better. We adjusted them a bit lower than driving light level since they will be on full time. The real object is to be seen and believe me those suckers sure fill that bill!! Man are they bright. Mounted down low and toward the engine guard outside presents a MUCH larger image to oncoming drivers. Sort of like comparing a VW to a Buick Roadmaster....
Jerry "Gold Rush" (aka: "SPOOK") San Angelo, TX
2015 GL1800/Roadsmith HTS1800
TOI - IBA #23804 (SS1K & BB1.5K)
I'm like an old race horse..... I can still run the race -- Just ache more at the finish line and need more rest between outings.
Yes on the drill and snake routine.
We took the engine guard off so I could drill into both mounting plate faces way low then did a hole up higher right under the two light mounts. Ran wires inside tubing then spliced on to the light pigtails. Heat shrink on the joints and pulled the wires back into the engine guards. We removed the head light and hooked directly onto the low beam power feed and ground wires. LEDs draw such little current the OEM wires don't even know they are there. Especially since the headlight is also LED.
Very nice and exceptionally nice looking, Lola.
Nice craftsmanship, Jerry.
Great Job!
Nuc
Thanks for the kind word guys!!! That is why Lola rode all the way up here to my place. Well that and she needed some saddle time in preparation for a long ride in a few weeks.... It takes some creative thinking sometimes but keeping wires out of sight and out of danger usually is worth the extra effort.
That really is nice.
Well, what can I say....leave it to Jerry to make an application unique, functional, and good-looking!
Carla
The stealth lights made a difference for me. I was more concerned with day time lights than night. My led headlight and passing lights would wash out with the bright sunlight in the desert. The 2 steaths added on the guard rail added that nice pattern that was different, eye catching. Jim
Nice job on the install
Very professional job
Guess we dont have to worry like the fear folks said about the low voltage lights reeking havoc with can bus wiring
Thank you Jerry 4 a clean install
Me thinks you made a lady rider VERY happy
Update on install..
Lola called the other day to tell me she noticed the pass/drive lights went out when switching to High Beam head light. HUMMMM .. We just knew we had looked to see if the low beam stayed on along with the high beam. Only thing we can think of was that this is managed internally in the LED head lamp cluster - not requiring actual 12 volt input on both wires.
Anyway, She rode back to San Angelo this morning and I successfully installed a power routing circuit I'd designed. I'll attach a copy for anyone that might want their LED Stealth lights on full time.. Everything still is contained inside the head lamp bucket so the installation stays neat and out of harms way.
