Likes Likes:  6
Results 1 to 12 of 12
Thread: Adjusting Parking Brake
    150+ Posts
    Jun 2015
    Yorktown, VA
    Default Adjusting Parking Brake
    My parking brake isn't holding the bike anymore. I got the service manual out and unloosened the nut holding the hex rod. When I turn the rod it rotates the round tube the cable runs through. Do I need to visegrip that down to make adjustments?
    Quote Originally Posted by 52edub View Post
    What year free do you have...?
    200+ Posts
    Apr 2014
    Pt Charlotte FL
    Year doesn't matter. Just hold the cable cover with your hand
    See # 29, hold the front of this with a pliars while you turn the barrel
    150+ Posts
    Jun 2015
    Yorktown, VA
    Thanks Jack. I will spray it with some penetrating oil and get the vicegrips on it.
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    I've never needed anything other than wrenches. Loosen up the jamb nut and then turn the hex rod with a wrench. Everything will rotate as needed. Sometimes it will take a bit of tension before everything rotates along the cable path. Adjust so it holds on the 4th click down.
    Bob
    Sometimes it will take a bit of tension before everything rotates along the cable Bob, if u hold the front part of the adjuster u should not feel the tension, I can then turn the adjuster barrel with my fingers. Try it next time just for grins and let me know if it works 4 u
    150+ Posts
    Jun 2015
    Yorktown, VA
    The hex rod finally broke free and I got the brake adjusted. Probably two years of water spray really made it tight. I ran it out more than needed and put some anti-sieze on it before I adjusted to where it holds the bike.
    Good job, put the rubber boot back on, I like to pack a bit of
    in the boot and use new zip ties front and back on the boot
    2000+ Posts Rollin Thunder's Avatar
    May 2013
    SUN CITY WEST. ARIZONA
    Just my 2 cents since I have a 14 HD Tri glide.
    I just put it gear and it doesn't go any place.
    Yes I know it won't start in gear. Yes...you have shift into neutral 1st .
    Like I said my 2 cents worth lol.. Rick
    150+ Posts
    Jun 2015
    Yorktown, VA
    Squirt it with some penetrating oil, wait a bit and then grab the round portion of the rod (pliers or visegrips) while turning the hex portion with a wrench. Mine broke free very quickly. I turned it way past what I needed so could add some anti sieze to the rod. Adjusted per service manual tires on the ground.
    150+ Posts Triglide1950's Avatar
    Sep 2017
    Chanhassen, Minnesota
    Default Parking Brake
    I'm new to TT. Last night I was thinking about my parking brake and it not holding. So this morning I did a search here on TT. Found the exact answer to the problem. Thanks guys for the help. Also you can start a trike in gear. Pull until the clutch, put your foot on the brake and hit the start switch.
  1. Parking brake
    By M2102 in forum Honda Trikes
    Last Post: 05-11-2017, 06:23 PM
  2. Parking Brake Help
    By pioneer11 in forum Harley Freewheeler / Road Glide 3
    Last Post: 10-17-2016, 06:58 PM
  3. adjusting the park brake
    By Capt Lou in forum Harley Trike Conversions
    Last Post: 03-29-2014, 06:22 PM
  4. Parking Brake Adjusting
    By cruderanger in forum Harley Trike Conversions
    Last Post: 06-30-2013, 07:55 PM
  5. Parking Brake
    By tubaman4 in forum General Discussion
    Last Post: 07-09-2008, 03:35 PM
