14TG2TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG214TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  4
Results 1 to 20 of 20
Thread: Goldwing Trike Recommendations?
    10+ Posts SouthJerseyRider's Avatar
    Aug 2017
    Vineland, NJ
    Default Goldwing Trike Recommendations?
    I have an Indian Roadmaster CSC Trike but one of the guys I ride with wants to buy a goldwing and turn it into a trike. He is wondering what would be the top 3 choices for conversion kits to consider for his goldwing? Any suggestions?
    Ed
    1000+ Posts mhgoldwing's Avatar
    Mar 2011
    mountain home,ar. USA
    Roadsmith or California Sidecar -
    Wing with Roadsmith kit, Traxxion Ak20 cartridges and Accuride System.
    07 ST 1300 for two-wheeled fun!
    Jun 2008
    Lovington, NM, U.S.A.
    If he wishes to do the work himself choices are limited. Champion, Roadsmith and DFT.
    Retired trike builder
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    Quote Originally Posted by SouthJerseyRider View Post
    I have an Indian Roadmaster Trike but one of the guys I ride with wants to buy a goldwing and turn it into a trike. He is wondering what would be the top 3 choices for conversion kits to consider? Any suggestions?
    Ed
    Is he doing the installation his self?
    Aug 2017
    Vineland, NJ
    absolutely not, not a mechanic type guy.
    Quote Originally Posted by Lucky View Post
  6. #6
    100+ Posts Grandpa1's Avatar
    Apr 2013
    Wichita Falls, TX
    California Sidecar Viper has a 5 year warranty. Just sayin'!
    I loved mine.
  7. #7
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    The easiest and most obvious choice for me, after completing all the research, was the CSC Viper kit by California SideCar. Over the past 1 1/2 years, CSC spent a lot of phone and email time with me. They responded professionally, quickly and with a "solid good customer relationship" attitude.
    I had the opportunity to speak with Dwight (in operations), Cassidy (in customer service) and Will (in tech support) on the Viper kits and their components. They were instrumental in helping me understand their product and all of the related accessories.
    CSC manufactured and delivered the kit as originally scheduled on time.
    See my build thread HERE.
  8. #8
    70+ Posts TerryD23's Avatar
    Sep 2017
    Brodheadsville, PA
    I kinda jumped into the trike thing after not riding for a few years. Saw a local Goldwing with 2014 Motor Trike conversion. Was beautiful. Rode it & bought it. Read about CSC and liked what I read but it seemed they were more expensive and I wasn't certain I wanted to go there. (At least yet.) I read nothing really negative about the Motor Trike kit so I'm curious what the general opinion here is on Motor Trike? Thanks
    My own follow up: I've been hopping around the forum and see some favorable and some unfavorable MT "reviews." I guess it's like anything else mechanical. Some degree of luck is going to be mixed in no matter what conversion one may buy.
  9. #9
    40+ Posts slug's Avatar
    May 2008
    Fayetteville, Ga.
    I like Eurowing conversion. With that being said whatever you choose the kit is only as good as the installer.
  10. #10
    600+ Posts keepinon's Avatar
    Dec 2011
    New Caney, Tx
    Quote Originally Posted by TerryD23 View Post
    I kinda jumped into the trike thing after not riding for a few years. Saw a local Goldwing with 2014 Motor Trike conversion. Was beautiful. Rode it & bought it. Read about CSC and liked what I read but it seemed they were considerably more expensive and I wasn't certain I wanted to go there. (At least yet.) I read nothing really negative about the Motor Trike kit so I'm curious what the general opinion here is on Motor Trike? Thanks
    My own follow up: I've been hopping around the forum and see some favorable and some unfavorable "reviews." I guess it's like anything else mechanical. Some degree of luck is going to be mixed in no matter what conversion one may buy.
    I've owned two. First was a single axle kit on a Valkyrie. No real problems, other than my stupidity. I liked to hot-rod too much back then, twisted a couple of drive shafts.
    On my '07 1800, I have the Adventure kit, IRS. I bought it used with near 11K miles. Right away I installed the new "green joint" grease-able drive shaft. I have since put over 50K miles on it with absolutely no problems.
    ....knocking on wooden table now.....
    ​2007 Goldwing w/MT Adventure conversion
    IBA: 65855 SS1000, National Parks Tour, Master Traveler Award
    https://www.dosgreengoes.blogspot.com
  11. #11
    Sep 2017
    Brodheadsville, PA
    Quote Originally Posted by keepinon View Post
    Not familiar with the green joint drive shaft. Will do some research on that. Thanks for the input.
  12. #12
    Dec 2011
    New Caney, Tx
    Terry, if you pull the right side cover, where you check/add oil, you can see the front u-joint thru there. The original was black, I believe the second gen was gray, the final improvement had a green front u-joint, with one of the cups drilled and tapped on the end and a grease zerk installed. That end position seems kinda funny, what with all other grease zerks I've seen being installed on the cross within the u-joint. But with that zerk on the end of the cap, it is easy too push on a grease gun and give it a few pumps. About three is all mine ever takes.
    But ya still gotta jack it up to get to the rear conventional u-joint. Takes all of five minutes to grease both.
  13. #13
    Sep 2017
    Brodheadsville, PA
    Good news is that mine is green. Bad news is that the side cover doesn't reveal enough for me to access the zerk. I can see it, just can't get to it! I don't have a grease gun with the flexible hose at the end. Will have to get one and try to fish it.
    Separately, I was checking the CV boots. Noticed that three allen wrench screws on the outside of the left boot were very loose! Two in fact were half way out. I tightened them best I can but not sure I was able to tighten them to spec. Think I better set up an appointment and get her checked over.
  14. #14
    300+ Posts paid4c4's Avatar
    Mar 2016
    Crestview Hills, KY, USA
    i have had two trikes, my first was a 2006 Motor Trike which I liked. I was able to trade up to a 2012 CSC which I like a lot more. I would definitely recommend CSC.
    Bill
  15. #15
    1500+ Posts leo3wheel's Avatar
    Aug 2011
    Cranford, NJ, USA
    Mgammon has 2008 Goldwing w/2012 Roadsmith Trike and trailer for sale in Classifieds.
    Leo TOI #617
    (Jeannette)
    09 RSV Black on Red with Hannigan trike conversion
  16. #16
    30+ Posts
    Apr 2017
    long branch n.j. monouth
    Default trike kit
    have a dft kit on mine , love it easy to service yourself , uses honda driveline
  17. #17
    250+ Posts wehrme's Avatar
    May 2014
    Decatur, IL
    I have a Motor Trike Razor. Love it. Turn a trike upside down and they're all sisters :0) Pick the one you like. Remember, you'll have it for a looong time. You'll hear comments from all trikers favoring the one they ride now. Conformational bias. I chose the Razor because I like the style. To me, all other mfg's trikes all look the same - and some kind of bland.
    Brother Mike
  18. #18
    Sep 2016
    Springfield, Mass. USA
    Roadsmith, Roadsmith, Roadsmith
  19. #19
    250+ Posts G.W. Viper's Avatar
    May 2016
    Rancho Belago, Ca, USA
    CSC Viper here. Both the wife and myself love the ride. Get compliments all the time. Also with that 5 year warranty....hard to beat.... Had it for 1 1/2 years...no problems at all.
    2015 Goldwing 1800 W/ 2016 C.S.C. Viper Trike Conversion
  20. #20
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    1. Just a matter of opinion. I like Ind rear. , some say more moving parts. Mine is a DFT. 20 years old. Still ticking with 70,000 on it .. I can feel the bumps on the straight axle Wife felt it even more. Rear passenger comfort better on a IND.
    When I am gona fix something I will fix it. You don't have to bug me every 6 months.
    FB Northeast Region Trike Riders
  1. Aftermarket GPS Recommendations?
    By oldNbold in forum General Discussion
    Last Post: 08-09-2017, 09:33 AM
  2. Replies: 6
    Last Post: 05-04-2016, 07:41 AM
  3. Fog Lights Recommendations for Goldwing
    By 6X3 in forum Honda Trikes
    Last Post: 11-28-2014, 10:22 PM
  4. Trike Tie Down Recommendations
    By ladywingrider in forum Honda Trikes
    Last Post: 08-29-2012, 08:28 AM
