Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  5
Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
Thread: Will not start in gear
  1. #21
    200+ Posts
    Sep 2017
    SE Tn
    My Son went to start my 17 Tri-Glide, To take for a ride and he said it won't start in gear, So i told him take your finger off the start button, Step ''Hard'' on the brake pedal clutch in all the way, ''Now'' press the start button.....Started right up...And thats the way i start it every time...
    And if that doesn't work for you then the brake switch is bad...
    Thanks. I think I tried all that but next time it fails I'll try pressing harder on the brake and see.
  2. #22
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by TriTn View Post
    Just so we're on the same page.....You press hard first...
    ''Then'' press the start button...
    2019 Tri-Glide.......
  3. #23
    200+ Posts
    Sep 2017
    SE Tn
    Yes
  4. #24
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    I just remembered something that occurred on my 2011 related to this subject.
    I have leather lever covers on my front brake and clutch levers. If I did not pull the clutch all the way in, hard enough to compress the leather sleeve on the lever, the switch would not trigger, not allowing the starter to engage.
    Similar issue to having over-sized grips.
    www.DKCustom.com
  5. #25
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    That will cause the no-start....Also if i put my adjustable clutch lever on the #1 [closest to the grip] setting that will cause the no-start..
  6. DKCustoms postbit
  7. #26
    200+ Posts
    Sep 2017
    SE Tn
    Ok, so mine failed to start in gear again just a bit ago. I tried all the suggestions about pressing hard on the brake, pulling hard on the clutch lever and made sure I was doing every thing in the right sequence. While I was sitting there thinking I pulled in on the clutch lever and let it slip off the tip of my fingers and snap back. Tried again and it started. It seems mine must be in the clutch switch. When it's working right I don't have to apply extra pressure on anything.
  8. #27
    200+ Posts
    Sep 2017
    SE Tn
    I found my problem. I took the cover off the left side switch. Four little screws hold that switch in place. The top right side screw, the hole in the little bracket was broken off. So the top right is not held in snuggly and doesn't always activate the switch.
    ETA: Thunder Creek in Chattanooga said they would fix under warranty even though I traded at Smoky Mountain in Maryville which is 70 some miles away.
  9. #28
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Good on you
    NOW throw some white lithium grease in the lever @ the perch when u pull the clutch in, this will help the action @ the pivot just a bit
    Where # 13 (bushing goes thru the lever)
  10. #29
    200+ Posts
    Sep 2017
    SE Tn
    Thanks Jack, where can I find a drawing like that showing the switch housing and the switches?
  11. #30
    5+ Posts
    Jul 2017
    usa
    Default clutch switch
    my 2017 TG would not start in gear even with the clutch pulled in and brake applied.
    it was a bad switch.
    only 2900 miles so it was replaced under warrantee.
    now no problem
    ride safe
    geo
  12. #31
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Welcome To Trike -Talk, George..... Good to hear your starting problem was fixed............
  1. Should I be able to Start while in gear?
    By hardwickbv in forum Harley Tri Glide
    Last Post: 05-20-2017, 10:50 AM
  2. Failing to start whilst still in gear.
    By extreme10 in forum Honda Trikes
    Last Post: 09-16-2016, 08:40 AM
  3. Can't start in gear???
    By MB1953 in forum Harley Tri Glide
    Last Post: 10-30-2015, 08:13 PM
  4. Can No Longer Start In Gear...
    By FLRT in forum Harley Freewheeler / Road Glide 3
    Last Post: 10-20-2015, 10:37 AM
  5. 014 & pull in clutch to start in gear?
    By Beorn of Ga in forum Harley Tri Glide
    Last Post: 09-09-2014, 06:55 PM
