Likes Likes:  7
Results 1 to 12 of 12
Thread: Building a trike from scratch
    1+ Posts
    Sep 2017
    Porth
    Default Building a trike from scratch
    Hi everyone, I have been riding a moped since 16 and have come to love riding, so I wanted to build my own trike now that I am turning 17. I want to build it completely from scratch but I have no idea where to start. My dad is a mechanic so I can use his tools and such, and he advised me to start with a VW rear drive engine but I don't know which one to use. On top of that, I don't know where to look for trike parts for sale to compare what I want, so I came here seeking advice. Thanks.
    33500+ Posts
    David357's Avatar
    May 2015
    Hobe Sound, FL.
    Hi Jack,
    to Trike Talk from South Florida.
    There are many experienced VW trike owners here on the forum to help answer your questions.
    80+ Posts Gator Monroe's Avatar
    Aug 2017
    Oak Run Ca. USA
    This is a Money Pit victim I can get behind ! (The Kid will have a chick magnet rig and Transportation that will draw a crowd at cruise night )
    Aug 2017
    Oak Run Ca. USA
    Quote Originally Posted by David357 View Post
    Hi Jack,
    And inexperienced rookies (Me) like yourself (Start with an early 70s dual port motor )
    700+ Posts vwbug72501's Avatar
    Apr 2015
    Batesville, AR. 72501
    Jack,
    Where are you located? Is that Porth as in Wales? If so, first thing is to get a copy of the special construction vehicles equipment requirements from you Dept. of Motor Vehicles (MOT?). If in the US, this applies to your state of registration. You don't want to build something and then find out that you can't title or license it!
    Also, the build will take at least 2-3 times longer than you expect.
  6. #6
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    welcome aboard Jack
  7. #7
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Welcome in.
    Check out the tech tech tech thread in the stickies.
    An old vw is one of the easiest to frame up but are not so cheap and common to find anymore.
    Think about the look and how you are going to use it before your final decision.
    From scratch can be a lot of work. A lot of the parts will have to be custom made one of a kind.
    And if you are in the UK check out The Trike Doctor in Manchester. They have used, new and service parts.
  8. #8
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    Depending on your location, you might look at grabbing a used (completed) trike and do modifications to fit your needs/wants.
    Welcome aboard the most awesome trike forum on the net!
  9. #9
    Jun 2010
    Indianapolis, In.
    About 80,200 results:
    http://start.att.net/search/index.ph...ntext=homepage
    There ya go!
    However, if you can't use a torch or weld, you might consider buying one that needs mechanical work or restored, to start with.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
  10. #10
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Welcome 'Jack........I was going to say Hi Jack, But then 3 Black satellites will stop and zero in on my laptop.... Any way Welcome to Trike-Talk 'Jack...
    2019 Tri-Glide.......
  11. #11
    Aug 2017
    Oak Run Ca. USA
    Are Youngsters still limited to under 500cc for Motorbikes in UK ?
  12. #12
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    Welcome aboard Jack!
    I built my first trike with my father when I was around your age. It was a V6 http://3fowlers.com/firsttrike.html
    I built my 2nd Trike from scratch from a VW swing axle. (I would go with a IRS instead now that I have learned more)
    IRS vs Swing http://3fowlers.com/images/photos/tranny/image002.jpg
    As someone else already said it is a Chick magnet! In fact it is a magnet for everyone. Everyone young, old, male , female and some I could not tell the difference have stopped to talk to me about it.
    You can see how I built it on this link http://3fowlers.com/
    I am now building one from a Chevy S10 Blazer http://www.triketalk.com/forum/threads/35590-88-blazer-trike
    Thank you
    Bob
  1. New to all of it. Building my first trike
    By Mcgee10 in forum New Member Introductions
    Last Post: 04-11-2017, 04:47 AM
  2. Trike building
    By rj100n2 in forum New Member Introductions
    Last Post: 12-16-2014, 05:03 PM
  3. Looking to build a V8 trike from scratch
    By BigLee263 in forum New Member Introductions
    Last Post: 08-01-2014, 10:36 AM
  4. Building a trike kit from scratch
    By junglebear in forum General Discussion
    Last Post: 09-07-2013, 08:28 PM
  5. need help building a v6 trike
    By warnerrd in forum Home Built Trikes
    Last Post: 05-12-2012, 10:08 PM
