Likes Likes:  4
Results 1 to 5 of 5
Thread: Hood wouldn't open!
    20+ Posts
    Sep 2017
    Rushville, Indiana, USA
    Default Hood wouldn't open!
    Has this ever happened to you. A couple of days ago I needed to lift the hood of my Stallion and it would only come up about two inches. I tried and tried to get it to go up but it wouldn't. Finally after a while I stood up in the trike and gave a quick jerk and the hood went ahead and raised up. I looked the lock downs all over and worked them by hand and even lubed them, but everything seemed to work just fine. When I put the hood down very slowly to see if something would catch it. What I found out was, the night before I drove the trike in a tight curve to the right in the lawn to park it and the cotter pin in the steering arm was catching on the back of the instrument panel. Mystery solved! I just straightened the front wheel a little and the hood worked just fine. It certainly had me going for a while.
    Jerry
    Glad it worked out for you. Those hood pins a tough to get at from underneath. WE all need to look at that pin to make sure it does not catch the body like yours did,
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Here is another hood latch issue. After 8 years of putting up with the occasional sticking latch on one side, today I took the time to see that the slack in the cable was not equal on both sides. Feel the slack or free play at the latch with the hood open. One side (right) had more slack thus not pulling open as evenly as the left side. I used a large crescent wrench and slightly bent the bracket which the cable comes through. Checked the slack on both sides, had to bend it a second time and now works better than it ever has. Tomg
    150+ Posts ODDOMAN's Avatar
    Aug 2010
    EFFINGHAM, SC
    Talking
    Quote Originally Posted by JerryC View Post
    Jerry
    I cut my cable off....don't use a locking system on front no more...
    ODDOMAN
    #667
    South Carolina
    Oct 2009
    Titusville, Florida
    By cutting the cables, you are eliminating a safety feature to keep the hood secure in the event of a possible accident. You might want to rethink that. Just my thoughts.
    Tomg
  1. Stallion Wouldn't Crank
    By Dean H in forum Stallion Trikes
    Last Post: 06-11-2015, 09:30 PM
  2. Lockaable Gas Cap and Hood
    By Switchback in forum Stallion Trikes
    Last Post: 10-22-2010, 12:31 AM
  3. Hood Adjustment
    By Silver Eagle in forum Stallion Trikes
    Last Post: 06-08-2010, 09:29 PM
