Speed Bleeders
Likes Likes:  3
Page 8 of 8 FirstFirst 1 2 3 4 5 6 7 8
Results 141 to 156 of 156
Thread: Stallion Trike Mods
  1. #141
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Default Re: Stallion Mods
    I really do not like the location. That is not a water resident unit. Wonder what he has attached to it. If it is some good stuff then I would suggest finding a way to seal it up.
  2. #142
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    Looking at the colors it looks like a fuse box. Maybe for acc.
    When I am gona fix something I will fix it. You don't have to bug me every 6 months.
    FB Northeast Region Trike Riders
  3. #143
    250+ Posts Dean H's Avatar
    Oct 2010
    Tampa, FL
    Quote Originally Posted by John Luciano View Post
    Per the address, it's a:
    Centech AP-2 Dual Fuse Panel
    Dean - 480.734.7161
    Tampa, FL
    dean.hauser3@gmail.com
    '09 Stallion #643
  4. #144
    50+ Posts
    Apr 2013
    Spirit Lake
    I think it might be a AP-1 upon slowing it down, but your right as for it being a Fuse block, thanks
    Quote Originally Posted by Dean H View Post
  5. #145
    350+ Posts Doc7402's Avatar
    Mar 2013
    Thonotoassa ,Fla ,USA
    Default Re: Stallion Mods A/C repaired
    well after almost a year I now have cold air ! Back in Jan. I had jacked the trike up and removed the right rear wheel and tried to add Freon to the system, but it leaked out as fast as I could put it in, with help from a friend I had him try to charge the system and I crawled under the trike and found where the A/C condenser was to have screws holding it a the radiator ( 4 ) two top and Two on the bottom were all missing causing the condenser to bounce around and wear holes in both gas lines with only 7K miles on it it didn't seam right ! I put in a call to motortrike spoke with Rich and they ordered both gas lines for it . to my surprise their both one piece about 7 1/2 foot long. As at this time i'am unable to get under it again so I asked my friend to come over and check it who is a A/C Tech . instead of replacing both gas line he was able to cut and remove both ends behind the rear wheel welded the holes closed and replace them and recharge the system bottom line I have cold air first time since buying the Stallion now if it will just stop raining i'll take it out and try it before the next Parade i'll be doing on the 4TH of July ,but I do have a question for those who have air does it work ? or just help to keep you cooler ?
  6. #146
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    If you get one of those hoses to direct the air on to you yes it works. Really there is to much surrounding air for the little bit of air that can come out of that one vent to over come. Now the heat helps a lot on those cold days. Really the A/C is there because it came with the drive train. Does help a little have fun.
  7. #147
    20+ Posts
    Jan 2011
    blairsville ga usa
    Default stallion hood mods
    has anyone added some type of "scoop" to hood to improve engine air flow?
  8. #148
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Have not seen one, but why do you think air flow needs to be improved?
  9. #149
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    If anything needs to be done in that area, it would be to keep some of the moisture off the engine in the rain!!!
  10. #150
    30+ Posts
    Oct 2015
    Tucson
    Default Baker modifications
    How do the Baker wings on the sides and top of the windshield change the amount of air on the backseat driver?
    There is a set of yellow running lights when I am in a State that doesn’t like my green running lights. There is three light kits underneath on set is computer controlled and the inside is lit up with green led’s. The stallion looks awesome after dusk on but you still can see them just not as much in the daylight.
    You can see the cruise pedals match my gas and brake pedals.
    The seat foam was replaced by Bike Solutions and I don’t hit the seat pan anymore and the wife likes it too.
    I didn’t replace the horn, that will be done another time.
    Mounting the under lighting and routing the wires was very time consuming.
    I hope I hit all the area’s if not I will post again.[/QUOTE]
  11. #151
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Nice job
  12. #152
    3000+ Posts Ed Hobgood's Avatar
    Jan 2011
    Dexter, MO, USA
    Nice photo's thanks
  13. #153
    70+ Posts Wingdesigner's Avatar
    May 2017
    Livonia, MI, USA
    Default Question for group--mods for short people
    Hello all. The Queen would like to take over the Stallion as her personal ride (something about the need for speed), but the pedals won't come up far enough, especially the brake. She seems OK w/the accelerator, but can't reach the brake more than just tippy-toe. In order to even do that, she's basically right up against the steering wheel, so no back support, either. Any ideas on getting those pedals higher/closer than stock? Platform boots are out of the question.
    She has a similar problem with our GW trike, which I'll look in that forum for ideas.
    Thanks in advance,
    WD
  14. #154
    Mar 2013
    Quote Originally Posted by Wingdesigner View Post
    Thanks in advance,
    WD
    try PEP BOYS auto or O'rielly's and try new brake peal covers will raise about an inch when i was 7 or 8 on the farm dad cut a piece of wood from a 2 by 4 the shape of the pedal and then put a cover over it so i could reach the pedal....
  15. #155
    100+ Posts 1 triker's Avatar
    Dec 2018
    Hempstead,tx,Waller County
    Hi all, I converted my fog lights to driving lights, I did not like having one light on the front of my Stallion. It looked as if one of the bulbs were out.
    # 796
  16. #156
    Dec 2018
    Default Storage Pouch
    Has anyone installed some sort of storage pouch on container in their Stallion?
    # 796
  1. Mods for GPS
    By dadorfman in forum Accessories
    Last Post: 10-09-2013, 02:40 PM
  2. What Mods to Get?
    By Big Blue in forum Harley Tri Glide
    Last Post: 06-12-2013, 10:26 AM
  3. 82 GL-1100 Mods
    By Calman in forum Honda Trikes
    Last Post: 01-29-2012, 06:15 PM
  4. What camper mods?
    By Ozarkryder in forum Trailers / Campers
    Last Post: 06-24-2011, 10:19 PM
Tags for this Thread
