Speed Bleeders
Likes Likes:  0
Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
Thread: Stallion Overheating
  1. #21
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Does the fan come on when you turn the A/C on? The 3 relays are the same relay, they are interchangeable. Sorry I do not remember which does what. I just kept swapping them out until I got it to work. Last choice maybe the fan itself has gone bad. You can un-plug it at the bottom and run jumper power to it to see if it will spin up. Keep us updated.
  2. #22
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    Quote Originally Posted by Gorilla View Post
    Fan does not come on when a/c is turned on. I have two or three of these sensors go out in the past, so I am familiar with how they act. My wife and I traveled over 150 miles yesterday by stopping and letting it cool off every 20-30 miles. I was pretty amazed with how far it will go without fan cooling.
    Thanks for the response.
  3. #23
    3000+ Posts Ed Hobgood's Avatar
    Jan 2011
    Dexter, MO, USA
    The middle relay operates the fan. I had the same problem last year and tracked it down to the relay under the seat. Hope this helps!
  4. #24
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    Quote Originally Posted by Ed Hobgood View Post
    Thanks a lot Ed!!!!!
  5. #25
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    Update on my fan problem. I have a small 12 volt battery. I removed the fan relay from it's socket and connected the battery to the ground and the hot wire to the fan circuit on the relay recepticle. The fan came on like a siren!!!!. The old relay looked as if the terminal going to the fan had overheated. I picked up a replacement at O'Reilly, $16.21 incl. tax. I would like to know what component the remaining two relays operate. In the picture below the red circle is where the relays are stowed under the crossmember. In the other picture the three relays are pulled out for access.
    Thanks Ed and Ted for your help. <br />
    <font color="silver"><font size="1">- - - Updated - - -</font></font>
  6. #26
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    Sorry about double posting the two pictures above. I did try to remove one but time ran out, we only have 10 minutes to edit. I also resized the pictures to just over 100kb, but one of them still comes out too large. Request admin remove one of the double post. Thanks.
  7. #27
    350+ Posts Doc7402's Avatar
    Mar 2013
    Thonotoassa ,Fla ,USA
    Quote Originally Posted by deanone98 View Post
    Has anyone had any issues with their Stallion overheating? I put a couple hunddred miles on mine today coming back from a Rally and noticed the heat gauge was on hot. Water is good, fuse is good and no plastic is caught up in the fan. I am thinking that it may be the relay switch? I can pull over and let it kool for 30 min and then on my way again pulling my trailer and after 10 miles on the freeway it heats up again. Any suggestions? Of course this happens on a Sunday with no one open to do any consulting with.
    any one know the part # number for the heat temp switch behind the right side rear wheel on the water line ,as i'am sure mine is now bad and want it in hand to be ready to change it..
  8. #28
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    Quote Originally Posted by Doc7402 View Post
    Here is a direct link to order from vintage air.
    http://www.oldairproducts.com/catalo...c2ea30f6c1dbe0
    The pn is 24-0098
  9. #29
    Mar 2013
    Quote Originally Posted by trikervet View Post
    The pn is 24-0098
    thanks for the input I was hoping I could get from a suto store pep-boys discount auto or such
    The pn is 24-0098
    also do we know what car or truck used it ?
  10. #30
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Just as quick to order it on line from them. You will get it in a couple of days. I ordered 2 so I would have a spare. I tried NAPA but they could not match it up. I did get one from them that worked well enough to get it home from Canada when mine went out. The temp range was not good enough the fan kept coming on and not running long enough.
  11. #31
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    I spent quite a while in an O'Reilly store once trying to match it up, they never could. It is made for a universal system, not vehicle specific.
  1. Considering a Stallion
    By Oldmanwheeler in forum Stallion Trikes
    Last Post: 01-18-2019, 07:48 AM
  2. It Well Be A Stallion!
    Last Post: 08-25-2014, 08:20 PM
  3. Looking for new Stallion
    By bigred06 in forum Stallion Trikes
    Last Post: 02-16-2014, 12:00 PM
  4. VRV and Stallion
    By Big Dog in forum Trailers / Campers
    Last Post: 01-24-2010, 12:24 PM
  5. An '08 Stallion for 27.6K?
    By ultraboy in forum Stallion Trikes
    Last Post: 09-23-2009, 10:38 AM
