Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  8
Thanks Thanks:  4
Page 8 of 8 FirstFirst 1 2 3 4 5 6 7 8
Results 141 to 159 of 159
Thread: Stallion Parts & Maintenance Reference
  1. #141
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by Roadburns View Post
    We just bought our 2013 Stallion, but it was missing the driver backrest. We can’t seem to find one.
    Help!
    Andrew .........Welcome to Trike -Talk..........
    2019 Tri-Glide.......
  2. #142
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    welcome andrew i have one available
  3. #143
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Quote Originally Posted by Gorilla View Post
    Ted, you do know that the back rest for a '13 is different from out 08/09. Ours had a much larger support post than the '13. Tom
  4. #144
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Quote Originally Posted by tomg View Post
    Yes I do Tom. I have one of the newer design when they sent me the wrong one.
  5. #145
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    Default Removing front wheel
    Silver Devel, you did more steps than necessary to remove the front wheel. I am going on thirteen years with my Stallion and I have done it a few times. I learn something every time!!! Thanks.
    Quote Originally Posted by silverdevil View Post
    the tools needed to change out the front tire on the Stallion
    go to page 49 in the little Stallion Manual and follow the steps up to step #5 on page 52.
    the following is some of the steps from the manual WITH the TOOLS added.
    REMOVING YOUR FRONT WHEEL
    ON PAGE 49 AND 50
    ITEM # 5 ON PAGE 50
    REMOVE LOWER SHOCK BOLTS
    ( ALLEN HEAD SCREWS)
    8mm ALLEN WRENCH
    ITEM # 6 ON PAGE 50
    LOOSEN THE FOUR PINCH BOLTS
    3/16" ALLEN WRENCH ON BOLTS
    7/16" WRENCH ON NUTS
    ITEM # 9 ON PAGE 50
    LOOSEN CALIPER SLIDE BOLTS
    22mm SOCKET OR 7/8" SOCKET
    ITEM # 10 ON PAGE 50
    REMOVE THE BRAKE CALIPER STRUT.
    14mm NUTS ON BOTH ENDS.
    7/32" BOLT ON FORK TUBE END. (ALLEN HEAD)
    ITEM # 11 1/2 (NOT LISTED)
    TO REMOVE THE FRAME THAT HOLDS
    THE BRAKE CALIPER USE A
    7/32" ALLEN WRENCH
    ITEM # 12 SLIDE THE AXLE OUT
    30mm WRENCH OR SOCKET
    THE SWING ARM THAT THE AXLE GOES THRU
    AT THE BOTTOM OF THE FORK TUBE USE
    6mm ALLEN ON THE BOLT AND USE
    17mm OR 11/16" WRENCH ON THE NUT
    TOOLS NEEDED
    6mm, 8mm, 3/16, 7/32" ALLEN WRENCH
    14mm, 17mm, 7/16" WRENCH (REGULAR)
    IN PLACE OF THE 17mm YOU CAN USE
    A 11/16" WRENCH
    30mm SOCKET OR WRENCH FOR AXLE NUTS
    22mm OR 7/8" SOCKET (MUST BE SOCKET) # 9
    hope this answers your questions on what tools are needed
    I did not change out the bearings, the wheel bearings just need lube added, a good wheel bearing grease.
  6. #146
    1+ Posts
    Jun 2021
    29 palms ca us
    Default Bearings replacement
    Anyone know what bearings I can cross reference to. My bearings are shot. Front tire of a 08 stallion
  7. #147
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Quote Originally Posted by Americanflagstallion View Post
    https://www.triketalk.com/forum/thre...ront-axle-seal
    Welcome Raul check out the above link. There are several articles on the Stallion section about the front parts replacement.
  8. #148
    1+ Posts
    Apr 2021
    Grapeland, Texas
    Default Is it still available?
    I just saw this reply!
    Do you still have it?
  9. #149
    1+ Posts
    May 2022
    lake havasu city
    Default side curtians for my stallion
    where can I buy snao on side curtians for my stallion david
  10. #150
    300+ Posts
    Apr 2011
    Signal Mountain Tn
    Quote Originally Posted by davids60 View Post
    where can I buy snap on side curtains for my stallion david
    Check out this thread I posted a few years ago. There is a link to B&G upholstery who use to make them, but I don't know if they are still in business. Also shown are pictures of some I made a few years ago and I prefer them over the canvas ones I have seen. I do not run them in the summer as it gets pretty hot with the side curtains holding the heat in. Here is the thread:
    https://www.triketalk.com/forum/thre...-Side-Curtains
  11. #151
    5+ Posts
    Jun 2022
    Belmont NC US
    Default Looking to buy a Stallion
    Did I mis a For Sale section ? I am looking to buy a Stallion would be nice if it was along the East Coast , Close to Charlotte even better
    Tom
  12. #152
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Quote Originally Posted by 1turbofocus View Post
    Tom
    Tom I responded to your "PM" yes my wifes is for sale. The For sale section is at the bottom of the forum lists.
  13. #153
    1+ Posts
    Jun 2022
    Coventry Twp, OH, USA
    Default 2013 stallion what year ford transmission was used
    My husband took our Stallion apart a couple years ago because of a no start issue.
    Now trying to put it back together, he can’t find the bolts and nuts to attach the neutral safety switch to the transmission. Does anyone happen to know the size of the bolts and nuts or where we could find them?
    Thanks, Susan
  14. #154
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by Rocky456down View Post
    Thanks, Susan
    Susan I can’t help you on the bolts… But I can welcome you to Trike-Talk…👍👍..
  15. #155
    1+ Posts
    Jun 2022
    Default 2013 Stallion starting issues
    We found the bolts and nut and got the neutral safety switch connected again.
    the fuses are all good.
    just get a clicking sound when trying to start.
    we have a battery charger connected to battery and it says it’s at 100%.
    I seem to remember someone posting about either two wires or cables going from the steering wheel to the neutral safety switch.
    that may have been on a ford forum because I was looking there as well.
    it seems like people had the same problem on the rangers.
    does anyone know what engine and transmission were used in the 2013 Stallion.
  16. #156
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Susan all stallions had the 2007 ford ranger 2.3 motor and the 4 wheel drive transmission with the transfer case removed, with a custom tail housing replacing it. if the starter solenoid is clicking the starter itself might need to be considered.
  17. #157
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Whenever I hear a clicking sound when turning on the key/trying to start the engine no matter what the Charger says it’s a bad battery/ dead cell in the battery….
  18. #158
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Always check the battery for a full charge, 12.5-12.7 volts
    If you have easy access to the starter, hook a volt meter to the positive ( main ) terminal , and ground the other lead
    Have someone watch the volt meter while you try to start
    Does the volt meter change?
    If not there is probably a starter solenoid relay in the wiring, you can jump at the relay to try the starter also
    it may look similar to this
  19. #159
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Just to add ‘Take a set of jumper cables and jump start the battery from a car and see if it starts….?
  1. Used trike reference pricee
    By ben721364 in forum General Discussion
    Last Post: 04-27-2013, 10:43 AM
  2. Reference material
    By Phu Cat in forum Harley Trike Conversions
    Last Post: 02-07-2013, 10:16 AM
  3. Necessary maintenance
    By spiritdream in forum General Discussion
    Last Post: 06-02-2010, 11:59 AM
  4. Changes to the Stallion or New Aftermarket Parts?
    By Mattel in forum Stallion Trikes
    Last Post: 10-26-2008, 08:06 PM
Tags for this Thread
