Results 1 to 7 of 7
Thread: V8 Trike Cooling
    200+ Posts
    May 2011
    Orlando,Fl--USA
    Question V8 Trike Cooling
    Here is the scene:
    *a V8 trike with a radiator mounted in the rear.
    *The radiator has a single, large, electric fan on it.
    *The trike operates in the normal range.
    *The radiator and fan is moved to the front of the trike.
    *Will the trike run...
    1--The same temperature or
    2--Run hotter ?
    Please explain answer.
    Thanks to all...
    Ride safe!!! Lots of idiots out there!!!
    100+ Posts rrunner's Avatar
    Oct 2010
    Zuni, New Mexico, USA
    Default Re: V8 Trike Cooling
    My first guess is that it would run cooler. Now what got me thinking is that all depends on the thermostat that's installed in the engine. I would imagine it will run at the temperature of the thermostat. I too run a v8trike with the radiator at the rear with a single electric fan. I also run a 160 thermostat on the motor and have not overheated the most it gets to is about 200. Hope this is of some help.
    750+ Posts Bruce's Avatar
    Sep 2010
    NY, USA
    [QUOTE=drumdoctor;251370]Here is the scene:
    2--Run hotter ?
    The trike should run the same temp but on another note all the heat that the raid. puts out while on the front will be blasted right on you.
    10+ Posts JethroBodine's Avatar
    Oct 2014
    Springfield, VT, USA
    I agree with Bruce, adding that the rear mounted radiator would cool to temp easier having more coolant in the system and the added cooling in the tubes, radiator to engine.
    20+ Posts
    Feb 2012
    hohenwald tn usa
    i built a trike this summer using a datsun 4 cyl engine. i mounted the radiator in the rear. i was able to make it shorter than it would have been with the radiator in the front. also i did not want the heat from the radiator blowing toward me.
    100+ Posts butchvoss's Avatar
    Jul 2013
    patrick SC
    Quote Originally Posted by drumdoctor View Post
    Here is the scene:
    2--Run hotter ?
    Thanks to all...
    did that on my 4.3 build. used an inline electric water pump and adapters on engine. works the nuts. The radiator is sideways with a slight scoop hardly noticeable at all, My engine is totally enclosed and i sit over it. The idea was to save on length also.
    70+ Posts BMB Guns's Avatar
    Dec 2015
    Louisiana
    I've seen many pics of a rear radiator setup and will be going the same route. I will be running a 3.53T Detroit diesel. Not having that big radiator and fan in the way will be nice. I was thinking about using stainless exhauste tubing to pipe the coolant to the rear. I have a tig welder and know how to use it so setting up the plumbing shouldn't be a problem.*
    What kind of tubing/pipes did y'all use to run the coolant?
  1. Cooling Vest
    By bobcree in forum Honda Trikes
    Last Post: 12-01-2014, 08:14 AM
  2. Cooling fan
    By Big Red in forum Harley Trike Conversions
    Last Post: 06-04-2014, 05:11 PM
  3. Cooling fans
    By bigjim54 in forum Harley Trike Conversions
    Last Post: 02-02-2014, 05:00 PM
  4. Cooling Vest???
    By bayoudave in forum General Discussion
    Last Post: 08-13-2012, 07:33 PM
  5. Help on oil cooling solution
    By tryker55 in forum Harley Trike Conversions
    Last Post: 10-10-2011, 01:09 PM
Tags for this Thread
