LD-Ordie2Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
ADSavarese11Jack KlarichNew Member Introduct...New member from FL
ADSavarese11woodyNew Member Introduct...New member from FL
LD-Ordie2LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese11hardwickbvNew Member Introduct...New member from FL
ADSavarese11ol' schoolNew Member Introduct...New member from FL
ADSavarese11GorillaNew Member Introduct...New member from FL
ADSavarese11Marc HNew Member Introduct...New member from FL
ADSavarese11ADSavareseNew Member Introduct...New member from FL
ADSavarese11Phu CatNew Member Introduct...New member from FL
ADSavarese11trike ladyNew Member Introduct...New member from FL
ADSavarese11Uncle FesterNew Member Introduct...New member from FL
ADSavarese11rhino 2New Member Introduct...New member from FL
Results 1 to 5 of 5
Thread: Hannigan driveshaft
    Nov 2015
    tulsa
    Default Hannigan driveshaft
    im working on a 06 vulcan 1600 kawasaki with a hannigan trike kit the driveshaft needs to come out and be replaced is it possible to get shaft out without removing the complete convertion kit
    250+ Posts Hannigan Motorsports's Avatar
    Jan 2012
    Murray, KY
    BMW, I will ask our techs in the morning to double check my thoughts on this. If I recall the Vulcan is a kit we change the shaft out on so let me get back with you in the morning after speaking with them.
    Murray, KY
    270-753-4256
    hannigan@apex.net
    www.hannigantrikes.com
    Jan 2012
    Murray, KY
    BMW, it can be done but it is a lot more involved without dropping it down. it involves removing the left axle and swingarm assembly to access the rear driveshaft area. The driveshaft in that bike is a modified version of the factory one so an OEM shaft will not work.
    Murray, KY
    270-753-4256
    hannigan@apex.net
    Nov 2015
    tulsa
    Default Driveshaft
    While i was waiting i did exactly what you have described .i ran a bore scope in the drive line tube ,the front joint is bad for sure.So my next question is how do i get the shaft out and i need a lasting solution .Do i need a new shaft or is is serviceable
    Jan 2012
    Murray, KY
    BMW that driveshaft will have to be replaced as it is a non serviceable unit. Any indication on what caused the joint to fail upon your inspection?
    Murray, KY
    270-753-4256
    hannigan@apex.net
  1. Driveshaft
    By BUBBA in forum California Sidecar Trikes
    Owners Forum
    Last Post: 04-17-2019, 07:28 AM
  2. Driveshaft
    Owners Forum
    Last Post: 10-01-2012, 09:28 AM
  3. CSC Driveshaft
    By 3wheels in forum Honda Trikes
    Last Post: 05-26-2012, 11:44 AM
  4. driveshaft
    By sweat12 in forum General Discussion
    Last Post: 02-02-2010, 11:52 AM
