Results 1 to 11 of 11
Thread: heating rebar
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    Default heating rebar
    I have been making a lot of rebar yard art type of stuff lately.
    I have been using my Oxy/Acc with a cutting tip to heat the rebar.
    I know I should be using a rose bud tip and will pick one up soon.
    BUT
    I was told I could make/buy something that would fit on my BBQ propane tank that would heat the rebar plenty enough and be a lot cheaper.
    I have 3 BBQ size Propane tanks so I could use one of them.
    I need to be able to heat 1/2" rebar enough to easy bend it.
    I say Easy because some times like with the project I am doing now I have to bend rebar sticking up in mid air. Not a lot of leverage
    Anyone know how I would set something like this up
    Thank you
    Bob
    450+ Posts GrandpaDave's Avatar
    Jul 2013
    Hankinson, ND, USA
    I've used a propane hand torch attached to a 20 lb propane tank. Just google for propane hand torch. Home Depot and others carry this type of torch.
    Best of luck top you.
    Dave
    Sep 2014
    Moneta VA
    Quote Originally Posted by GrandpaDave View Post
    Dave
    but will that get hot enough??
    I have a hand held propane torch connected to a small propane tank but it will not get the rebar hot enough.
    Is there a special gun/tip used to get more heat?
    Thank you
    Bob
    300+ Posts
    Jun 2014
    S.E. Ohio,Close to the triple nickel
    You will need a tip for propane and a regulator for propane tank. This will replace the acc.
    600+ Posts keepinon's Avatar
    Dec 2011
    New Caney, Tx
    You can use propane instead of acetylene in your torch set up. It works fine for rosebuds, but for cutting you need a propane cutting tip. Most welding supply stores carry them.
    100+ Posts DPK's Avatar
    Nov 2014
    Little Rock AR
    "MAPP" Gas (yellow cylinder) is much hotter.
    Machinery has a mysterious soul and a mind of its own.
    I used a Perko acetylene torch.. To solder weld and melt gold, It will reach temps over 2000 degrees'F
    Simple and uses only one acetylene tank...More than enough to bend rebar...
    Sep 2014
    Moneta VA
    so there is no oxygen or Propane??
    Thank you
    Bob
    Quote Originally Posted by Fowler View Post
    Nope' Just one Acetylene tank, And it mixes with natural air...
    Sep 2014
    Moneta VA
    do you think that would heat up enough to bend 1/2 inch rebar?
    Can you point me to any good Cheaper setups (yes I am cheap)
    Thank you
    Bob
    Cyberweld sells them Give them a call...
    ==Smith air/acetylene...#835a The tank is extra you can get it at a welding supply house ....Looks like the one i have' But i bought mine 25/30 years ago.
    As an after thought stop by a local welding supply house and they may be able to set you up..
    200+ Posts RTwing's Avatar
    Mar 2014
    Minnesota
    I use my TIG welder to heat sheetmetal and 1/2 inch bar for bending it works very well but you have to have the heat set right and move the tip constantly so it doesn't groove into the part.
  1. Over Heating
    By dockside in forum Honda Trikes
    Last Post: 03-24-2016, 07:33 PM
  2. Over heating
    By skipg in forum Honda Trikes
    Last Post: 09-06-2013, 03:08 PM
  3. heating up
    By howardg in forum General Discussion
    Last Post: 07-09-2013, 05:26 PM
  4. VW over heating
    By B-2 in forum VW Powered Trikes
    Last Post: 02-16-2012, 04:03 PM
