dthorn1dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
Likes Likes:  1
Results 1 to 8 of 8
Thread: Knock, Knock...who's there?
    1+ Posts
    Sep 2016
    San Luis Rio Colorado, Sonora, Mx.
    Default Knock, Knock...who's there?
    Good afternoon,
    I have a champion trike kit that was installed in 2010. I have included pictures of where I think I am getting a loud knocking when going over bumps, pretty much any bump, in the road. It was suggested that it may be one of three things: 1) the mounting bracket for the anti roll bar; 2) the a-arm bushings; 3) the shock bushings. I was also told that if the rod end shown in the picture is the noise to adjust it to see if it changes. Problem is I have no idea how to do any of this. I am looking for some guidance. I do not live in the US and am not near any mechanics that are at all familiar with trike kits.
    Thank you.
    rjbii
Size:  69.7 KBName:  DSC05451 (2).jpg
Size:  730.1 KBName:  DSC05455 (2).JPG
    Sep 2014
    Box Elder, SD
    Welcome from New Mexico. I am not familiar with the gold wing, I know someone will chip in with a response. Good luck in getting it fixed. Jim
    3000+ Posts Ed Hobgood's Avatar
    Jan 2011
    Dexter, MO, USA
    Welcome to Trike talk from Southeast Missouri. Several questions, can you make the popping by rocking the trike when the trike is setting level and no rider on it? If you can you need to get under the trike and see if you can see any of the joints that are loose or the sound coming from a joint. Is the sound only coming from the back?
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    welcome aboard. Don't have knowledge on your trike, but someone should. You might try calling Champion and see if they have a suggestion on the issue. Keep us updated
    1250+ Posts bustedwing's Avatar
    Mar 2012
    Hermansville, Mich. USA
    Hello RJ and from the U.P. of Michigan welcome to the website That adjustable swivel will rattle with slack in the linkage if it is worn. On each end is a small swivel that will wear out . If you can move the linkage and make it rattle, replace it.
  6. #6
    4250+ Posts pcombe's Avatar
    Feb 2013
    casper,wy. usa
    Quote Originally Posted by rjbii View Post
    Good afternoon,
    Thank you.
    rjbii
    Suggestion:
    Go to champion web sight and download installation instructions, maintenance requirements and trouble shooting info?
    Its a large file but it's a champion bible.
    My solid axle champion rides pretty rough in town but smooth's right out on the highway.
    How about your swing arm bushings?
    I'm a Harley guy but those are my suggestions?
    Enjoy life now!----------IT HAS AN EXPERATION DATE
    1989 HARLEY DAVIDSON TOUR GLIDE ULTRA CHAMPION- A WOLF IN SHEEP'S CLOTHING-(CUT YOUR WOLF LOOSE!)
    the difference between a good trike and a bad one depends entirely on the integrity of it's builder!
  7. #7
    9750+ Posts Rod69's Avatar
    Dec 2011
    Lawrenceville Il. USA
    Welcome from Southeastern Illinois.
    Rod69 Illinois TOI #900
    Joan71 Illinois TOI #901
  8. #8
    1+ Posts
    Sep 2016
    Default thnks so much for the info.
    Quote Originally Posted by Ed Hobgood View Post
    ok, So I can make the noise w/out the rider. All joints, bolts, nuts, etc. seem tight, bushings seem real good, not dry or cracked. I took the linkage in the pictures apart and checked them to see if there was anything obvious, and nothing. So I put it all back together and now it isn't making the noise. So go figure.
    thanks again
    Quote Originally Posted by Rod69 View Post
    thanks to everyone for the welcome aboard.
    rjbii
    Quote Originally Posted by pcombe View Post
    Suggestion:
    The reason I am on the forum is because the guys at champion told me I could get the answers here.
    But I will look up the installation instructions and maybe there will be something that stands out.
    thanks
    Quote Originally Posted by bustedwing View Post
    Thanks, that will be my next move. It didn't seem to have much play at all but maybe it doesn't require much either. Appreciate the time. Thanks
    rjbii
  1. Suspension knock
    By TG Bob in forum Harley Tri Glide
    Last Post: 04-24-2016, 06:55 PM
  2. Knock Count and the PV or Are my Pistons in danger
    By FuzzyWuzHe in forum Harley Tri Glide
    Last Post: 05-23-2015, 03:24 PM
