Likes Likes:  10
Results 1 to 12 of 12
Thread: Clutch question
    30+ Posts
    Aug 2016
    Fort Mill, South Carolina, United States
    Default Clutch question
    Does anybody know if a Harley clutch master cylinder work with a VW slave cylinder. i would like to use this set up on my trike if it would work.
    thanks,
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Ok ....
    The volume of fluid to move the slave far enough is typically larger than a motorcycle lever can deliver.
    A motorcycle unit is in the 12mm to 15mm dia normally. That is not enough displacement to fully work the clutch.
    There are a few motorcycle units with larger bores. You will probably need 17 to 19mm bore to get there.
    But then you better have a kung foo grip. It aint an easy pull.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    So yes it has been done.
    First I would use a diaphragm pressure plate of the lightest poundage I could get away with.
    They take less total movement to work.
    Then the long lever on the throw out arm.
    Then the normal cnc style slave.
    And try a 15 to 16mm master.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    So how are you going to shift it?
    Ratchet?
    Apr 2015
    Batesville, AR. 72501
    I've got one of those! Requires rebuild of trans as stock shifter arms need to be replaced with tapped ones for the outside shift linkage. That's where I'm at right now, putting together a freeway flyer irs trans. Still dealing with the learning/tooling curve.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    You have this ratchet all built?
    I have Luis's acad prints on the machine shop parts if you need them.
    Apr 2015
    Yep. Luis does really nice work and he is real nice guy. I can send you pictures tomorrow if you want.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Luis is a facebook friend and he follows my group on facebook. He offered up the design prints to my group there. It is not complete as it does not list the off the shelf parts like springs and bearings.
    30+ Posts
    Aug 2016
    Thanks for the information. I do have room for a floor mount master cylinder on the floor boards but I wanted as much info before I made a decision which way to go. I am planning on using a EMPI shifter for a buggy.Name:  trike frame.jpg
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Yep a lot of the buggy stuff is excellent trike parts also.
    The super shifter is a good item, very nice compared to stock. There are better super high dollar shifters out there that do work good.
    But bang for the buck the ole super shifter is killer.
    Think about what hand you want to shift with also.
    If you left bar hand clutch it, then now you are letting go of the throttle to shift.
    Personally i very much like the "jockey shift".
    It makes me grin to stick shift the hot rod trike around. I left foot clutch, left hand shift. That way I can gas on it and bang out the gears.
    Think about how you want to operate it.
    It is not impossible (but difficult) to make a hand clutch and foot shift.
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    talking left hand shift....I,m using it on last winter over in homebuilt trikes.. recently installed handlebar turn sigs. when making a left turn while slowing down .....down shifting etc hand is on the shifter most of the time.I'm thinking of a left turn switch on the shifter itself???? any other ideas??? larry
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    I just juggle back and forth.
    And well.....I dont do much city driving either.
    Maybe put the switch gear on the right side?
  1. Rekluse clutch vs EFM auto clutch
    By Huelshorst in forum Harley Tri Glide
    Last Post: 03-28-2016, 09:11 AM
  2. 2013 TriGlide Clutch Question
    By JimmyDee in forum Harley Tri Glide
    Last Post: 10-24-2014, 07:58 AM
  3. New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    By usnavy8084 in forum Home Built Trikes
    Last Post: 10-21-2012, 08:18 AM
  4. Clutch Ease question
    By Skeet7373 in forum Harley Trike Conversions
    Last Post: 03-13-2012, 07:04 AM
  5. Question about clutch cable routing
    By JohnC in forum Harley Trike Conversions
    Last Post: 01-01-2012, 10:01 PM
