Likes Likes:  2
Results 1 to 5 of 5
Thread: will conversion make motor run hotter
    100+ Posts
    Mar 2017
    Bournville, OH, USA
    Default will conversion make motor run hotter
    My o3 does not have water cooled engine so can I expect it to run hotter with a trike conversion, I have made 4 trips to black hills rally and have seen daily temps around 116, auto were blowing tranny fluid on road ways making for un safe riding. I have road a few different models out there none ever over heated, I spent time riding from morning till after dark, did not spend it in camp grounds talking about riding, will I have to worry with air flow keeping engine cool with trike conversion,
    The plans are to make long runs out west or down southern states. will a add on oil cooler be a must?
    will be riding 2 up most time and pulling a trailer sometimes.
    I want to be able to ride long distance and only need to change fluids if needed.
    200+ Posts bronxbill's Avatar
    Jan 2016
    Raleigh NC
    I would guess that you will need an oil cooler, preferably one with a fan. Air flow past the body of a trike is not as efficient as it is on a two wheeler. Plus you are adding a lot of weight with the trike kit.
    2016 Tri Glide Black and Silver, VIEDS, LRS, DK Comfort Lift, DK 2" Tank Lift Kit, Road Zepplin Seat, Black CVO mirrors, K&N Air Filter, Wards Fans, Khrome Werks 2+2 Wide Sweepers.
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Hank62 View Post
    Yes, it will run hotter.
    Less air flow
    More weight
    More wind resistance is probably the biggest factor.
    An Oil Cooler will help, but there are many things you can/should do to cool down the engine.
    Here is a REPORT on why & how to cool down a Twin Cam engine.
    www.DKCustom.com
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    One of the simplest and most effective ways to cool your engine and engine oil is to install a set of the Love Jugs twin fans. Very simple idea, but they are well built and they just work.
    Your air cooled VTwin engine has cooling fins for a reason. That reason is because those fins act as giant heat sinks and are the most effective and in most cases the only way Harley motors can be cooled since most are air cooled only.
    Even the newer 'water heads' are not truly water cooled as they do not use water jackets around the cylinders like the metric bikes do. The piston and cylinders are the source of the heat and when you cool the cylinders you cool the oil that circulates through them.
    Read more from testers HERE.
    Jun 2010
    Indianapolis, In.
    Yes, it will run hotter.Less air flow Kevin
    Would appreciate an explanation of how adding a trike conversion restricts or lessens air flow over/around the engine when the conversion is behind the motor???
    With the fenders hanging out on a trike, creating a "back draft" at speed, I would think this would flow more air on the motor, especially the rear cylinder of a V-twin!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
  1. Trike Conversion OR New From the Motor Company?
    By Bigfoot21075 in forum Harley Trike Conversions
    Last Post: 06-07-2016, 04:58 PM
  2. Rattle 05 RK Motor Trike conversion.
    By sandrooney in forum Motor Trike
    Last Post: 06-12-2012, 06:16 AM
  3. 2010 Triglide hotter than HE77?
    By tkglider in forum Harley Tri Glide
    Last Post: 09-28-2009, 07:28 AM
