Likes Likes:  1
Results 1 to 3 of 3
Thread: Aux Fuel pump filter?
    Mar 2011
    mountain home,ar. USA
    Default Aux Fuel pump filter?
    1. 2011 HT1800 kit. Is there a fuel filter on the auxiliary fuel system?
    2. Best way to drain tank?
  2. Roadsmith banner
  3. #2
    Sponsor - Roadsmith Trikes
    TrikeTalk Sponsor
    Roadsmith Trikes's Avatar
    Mar 2008
    MN
    Quote Originally Posted by mhgoldwing View Post
    The filter is before the fuel pump. Follow the supply line from the auxiliary tank to the pump. The fuel line goes into the pump first (sequence is filter, pump, one-way valve).
    Easiest way to drain tank is to disconnect line from fuel filter and drain into an appropriate container. Might want to have something handy to pinch-off the line if necessary (needle-nose channel locks, etc).
    Let me know if any questions!!
    Jim
  4. #3
    Mar 2011
    Quote Originally Posted by Roadsmith Trikes View Post
    Jim
    Thanks for the info!
  1. Electric fuel pump pressure
    By Doug D. in forum VW Powered Trikes
    Last Post: 04-21-2017, 08:09 PM
  2. Fuel pump help
    By Nighttrain in forum VW Powered Trikes
    Last Post: 09-06-2016, 10:29 PM
  3. fuel pump
    By samsonone1 in forum Honda Trikes
    Last Post: 06-06-2013, 11:52 AM
  4. Fuel Pump
    By bigjoey38 in forum VW Powered Trikes
    Last Post: 06-12-2012, 12:55 PM
  5. Ok,Gravity or electric fuel pump?
    By warnerrd in forum VW Powered Trikes
    Last Post: 10-15-2010, 10:46 PM
