STALLION OWNERS- anyone know from what vehicle is the front wheel assembly?
I am at a stand still...........I have removed the entire wheel assembly...but have run into a couple of snags....I could not break loose the caliper pad retainer
bolts, even after applying a torch to try and melt the loctite holding them onto the rotor. I decided to remove the assembly from the rim and the machine shop
was unable to budge the outer seal with the fullest load possible. They decided NOT to try any further for fear of damaging the black housing surrounding them.
I have decided to replace the outer bearing on one, as the shop and two other friends said the other looked fine. Anyone have any suggestions?
I am trying to get this fixed so that we will be able to ride with those attending the Ormond Beach "Snowbird rally", the second week in Feb. Does anyone know
from what vehicle is this front wheel assembly...I thought I read somewhere on here, it was off a toyota FJ? or is it custom built from the factory?
Thanks in advance !!!!
