I need to find the shaft or if someone or company sells them
Different from stock?
As he has been out of business for a decade......and was not able to sell many.....the chances of finding a used/preowned one is very unlikely.
You probably will have to get one made at your local machine shop. You can make it by the bad ass trike instructions. His is not a very strong design or durable bearing setup.
I made my own and designed it to be a lot stronger to handle a hot rod engine.
[url]https://drive.google.com/file/d/0B291Vwl-NHGecW1lRWZ1UkNzam8/view?usp=drivesdk[/url]
That's a build it yourself item at this time since Bad Ass went out of business. Check out DeathBySnuSnu's "Anyone Else" build thread or his "Tech,tech, tech" thread for info about the driveshaft. I believe that he has CAD drawings also available for the shaft and adapters. The shaft is fabricated from stock VW trans parts and a length of steel shaft. A little welding and TADA! you got it.
