I can't seem to find out why left turn signal doesn't work. bike has led lites w/ flashing stop lites. everything lites up like crazy except this. trike is new to us (ebay). any help-thanx
Printable View
Are the front turn signals LED's? Are they aftermarket? If so, the won't work in conjunction with the brake/signal light system on the kit (back), without modifying. At least mine wouldn't when I tried to convert over. Simple thing to do is go back to the old style front signal lights.
If you mean on the back of the kit, I would use a test light to verify the light itself is getting the signal. Motor Trike uses a 4 wire light on the back so the turn signal has it's own wire. If you are getting voltage at the wire going into the light, then the led board is bad. If you are not getting voltage, I would start checking connections as well as the connection for the main harness behind the right side cover on the bike.
