Motor Trike Rear additional brake caliper upgrade - what master cylinder to use?
I see from a few posts on here that folks have fitted additional rear brake calipers to their MT and prob a few other machines too!
So question is - what large rear master cylinder did you use? Obviouslt stock one will not work and you now have doube or more the piston volume to move?
Ours is a 08 Goldwing GL1800 and someone put VW Golf GTi rear calipers with hand/parking brake function then fitted and addition 2 x 4-pot calipers for good measure. Result = NO rear brake - piston bottom on in master cylinder before it can move enough fluid.
As a gues as the oem m/cyl is 11/16" / 17.5mm it needs to go up to either a 19mm or better still a 22mm bore cylinder - again preferabley another Nissin unit but strugling to find one.
Anyone help?
