[COLOR=#333333]Fearless... "If I want more air I just turn the wings on the faring a little" You are correct about that. You can definitely put some air back on the rider and engine area playing with the fairing wings.
[/COLOR]
Printable View
[/COLOR]
[QUOTE=nucseal;601723]The lift kit is dependent on the space from your bars to your tank. You don't want your bars hitting the tank on a tight turn. So crank you bars from one side to next and measure the distance before you purchase. You also can move your bars up to accommodate the space, if it is comfortable for you.
The tank lift and deflectors are separate purchases.
I have installed the deflectors and they do help. I couldn't install the tank because my bars sweep back towards the tank.
Nuc[/QUOTE]
Thanks for the reply, I'll measure the gap and see what I'll end up with
[ATTACH=CONFIG]60503[/ATTACH][ATTACH=CONFIG]60504[/ATTACH][QUOTE=nucseal;601723]The lift kit is dependent on the space from your bars to your tank. You don't want your bars hitting the tank on a tight turn. So crank you bars from one side to next and measure the distance before you purchase. You also can move your bars up to accommodate the space, if it is comfortable for you.
Nuc[/QUOTE]that is why I chose the 2+2wide sweepers to make sure to cleared the tank they are convex. Ride safe Fred
[QUOTE=Tomswede;601714]What made you decide on the 1.5 "vs the 2" lift, is there a clearance issue ? Also, are the deflectors included or a separate purchase?
have you had any issues or concernes since you installed the parts?[/QUOTE]
Get the cool wing deflectors from Kevin, they definitely help cool the engine and all but eliminate the buffeting;)
[QUOTE=Fearless;601838]that is why I chose the 2+2wide sweepers to make sure to cleared the tank they are convex. Ride safe Fred[/QUOTE]
I can't fine them in gloss black. My trike is completely blacked out.
Nuc
[QUOTE=nucseal;601878]I can't fine them in gloss black. My trike is completely blacked out.
Nuc[/QUOTE] 300813 I will double check the number Khrome Werks check out the website Black just like I have Chrome. 2+2 wide sweepers. in case you are interested
[QUOTE=Fearless;601881]300813 I will double check the number Khrome Werks check out the website Black just like I have Chrome. 2+2 wide sweepers. in case you are interested[/QUOTE]
Nuc
