[QUOTE=Dragon;867383]Hi Ted
I know this is an old thread but do you know where you got your o-rings:D
Thanx
Dragon[/QUOTE]
sorry was not able to locate invoice
try search by the part numbers
Printable View
Thanx
Dragon[/QUOTE]
soures =Hi just wondered if you found out were i can by 2 sets for mine
Thanx
Dragon[/QUOTE]
[QUOTE=2009 ! Stallion;941087]soures =Hi just wondered if you found out were i can by 2 sets for mine[/QUOTE]
Earl, Welcome to Trike Talk on your first post..👍👍..
Earl Welcome aboard. The best I can suggest is use the info provided in my post from 2019 and see if you can find "O" rings to match. Good Luck
Hi Earl, :welcome: to Trike Talk and your first post
If you disassemble the calipers a good parts guy can match the o ring seals up for you
I would try a Napa or Car Quest jobber first
Thanks !!
[QUOTE=rhino 2;941089]Earl, Welcome to Trike Talk on your first post..👍👍..[/QUOTE]
[QUOTE=Gorilla;941113]Earl Welcome aboard. The best I can suggest is use the info provided in my post from 2019 and see if you can find "O" rings to match. Good Luck[/QUOTE]
Will Do Thanks for the info!!
welcome i got my set at grainger size 216 comes 5 to a package and the other size 024 comes 50 to a package material was viton. i could not find the square seal at napa or around here. don't know price was not expensive.
good luck
Dragon
[QUOTE=Dragon;941239]welcome i got my set at grainger size 216 comes 5 to a package and the other size 024 comes 50 to a package material was viton. i could not find the square seal at napa or around here. don't know price was not expensive.
good luck
Dragon[/QUOTE]
The square seal was not found by me either back in "19" but I used a round one of the same size and it worked well.
