2 Attachment(s)
[QUOTE=scootergmc;669040]Thank you. I'm attaching a picture of my rear end for reference.
[ATTACH=CONFIG]71455[/ATTACH][/QUOTE][URL]https://mjtrikes.com/shop/images/GG0650.jpg[/URL]
[ATTACH=CONFIG]71471[/ATTACH][ATTACH=CONFIG]71472[/ATTACH]
Mine is not so greasy, check close at pinion seal area.
[IMG]https://i220.photobucket.com/albums/dd22/CrystalPistolPics/CrystalPistolPics2%20Bikes/Bike%20Details/Recievermadeforour97GL1500SELehmanTrike2.jpg[/IMG]
Yeah, I know …. could use a cleaning & wax, huh? :D
Mine also has a different cover look, but same number of bolts and internal parts same. Not sure why Ford changed cover shape though. To find mine here, I looked at a '79 Pinto at Rock Auto.
To find your gasket, I looked up a '75 model Pinto. I think Ford used them both as they came off the train maybe. You have Ford 9" drum brakes.
[URL]https://www.rockauto.com/en/moreinfo.php?pk=127983&cc=1135246&jsn=543[/URL]
here is yours
[URL]https://www.rockauto.com/en/moreinfo.php?pk=127938&cc=1135167&jsn=454[/URL]
Thanks for that info. I appreciate it.
Hey Bob!
Welcome from Mid-Mo! By now you've figured out there's a host of folks on this forum more than willing to help out by sharing their wealth of experience, knowledge and information. Jim (Lee H. Mann) is the Lehman king and can tell you anything you need to know about your conversion.
This is a great forum and a great bunch of folks. I invite you to join the Gold Club, which supports the forum and gets you a ton of great benefits. Again, welcome aboard!
PEACE and ride safe! :Dorag:
Can't edit my prior post here now, but I meant to also point out that [B][COLOR=#0000ff]one [/COLOR][/B]6.75" Ford rear has a cover shape of essentially 8 sides …… while [COLOR=#b22222][B]the other [/B][/COLOR]is like 4 sided square with round large radius corners.The gaskets show it well, so even if bolt pattern was same, there would not be a seal at corners. As far as I could ever find out, other components are same, seals, bearings, etc. Shafts were shortened with housings, and re-splined by Lehman or a contractor of thiers.
If you ever see[B] leakage [/B]…. [B]fix it asap [/B]to save those axles if possible.
I did discover that these axles were used in [U]some [/U]early Ranger pickups and Bronco IIs as well as Pintos, Bobcats, maybe even 4 cyl Mustang IIs. I think more than adequate for our use.
Here's a better pic of mine without hitch parts in the way which is unlike yours in respect to cover shape/style. Pic from way back in 2004 when I bought it.
[IMG]https://i220.photobucket.com/albums/dd22/CrystalPistolPics/CrystalPistolPics2%20Bikes/Bike%20Details/Or%20GL1500%20with%20Xtractor_zpsvefz3uxj.jpg[/IMG]
Thanks. I'm going to pick up a gasket this weekend and throw some fresh 75w-90 in there. The previous owner told me it has no more than 300 miles on a service, but I'm not sure it included the rear end. It'll get cleaned underneath too so I can see what's going on if something decides to get super leaky.
