1 Attachment(s)
Pet water delivery system
So, as most of you know, my little buddy has only one eye and is getting on in years. He has a hard time getting water from his bowl. I've tried shallow bowls with just about a half inch of water in them, a water bottle (he won't use it at all), food coloring in the water so he can "see" the level (that actually helped a lot) and several other things to help him not get his nose so deep so he ends up choking on the water.
Think I have found the solution. Got it on Amazon and Harley loves it. Holds a half gallon and has a pump that circulates the water constantly through a filter. I only have to top it off daily and clean it out weekly. The big advantage is that it's about at his shoulder level and he can get a drink while his nose is above the water. So far ... so good ... he hasn't choked on the water in the first week of it's use.
It's designed for puppies and cats, but, it's perfect for his size. Amazing what we'll do for our little friends.
Here is his current setup, I turned the lights off so you could see the lighting which I'm sure helps Harley, also you can see the water level gage. The thing is really quiet and the light and moving water helps him "see" it better, at least I think so. The "pans" under his food and water came from Dollar Tree.
[ATTACH=CONFIG]83369[/ATTACH]
