[QUOTE=pwhoever;824599]I like that and it looks perfect. My only fear would be the cables for support although with both, they are supposed to be rated at 1500lbs. Thank you.[/QUOTE]
If weight on the ramp is a concern, I would just have a couple pre-made supports to place under each side of the hinge area. They only need to be a few inches high and would give you confidence using the ramp..... Jim
1 Attachment(s)
[QUOTE=cScjhb;824954]If weight on the ramp is a concern, I would just have a couple pre-made supports to place under each side of the hinge area. They only need to be a few inches high and would give you confidence using the ramp..... Jim[/QUOTE]
If my idea didn't work, I was gonna bolt these on each side.
[ATTACH=CONFIG]97753[/ATTACH]
