4 Attachment(s)
Kevin the alignment went without hitch as I posted else where the supplement doesn't mention disconnecting the panhard rod but a third grader would see it must be off to move laterally. That is when I found a worn Heim joint so I replaced both. Magnetic Laser Levels made this job simple. I'm waiting on a few other things I ordered before re-installing the body. It will be interesting to see how close the spacing is now on the fenders I have always had more space on the left side of trike (primary side) we shall see. I believe everyone with the tools and time should at least take the body off and look at what they are riding it's really neat to see, I believe I have a better understanding of what makes it so much fun. travel safe Fred
[ATTACH=CONFIG]67696[/ATTACH][ATTACH=CONFIG]67697[/ATTACH][ATTACH=CONFIG]67698[/ATTACH][ATTACH=CONFIG]67699[/ATTACH]
[QUOTE=Fearless;647567]Mothers 12" extended powerball takes the skinned knuckles out of that job. Zepher Pro-40 polish twice a year... [ATTACH=CONFIG]67552[/ATTACH][/QUOTE]I was thinking about trying one of those was not sure how good it would work. May pick one up.
[QUOTE=Longbeard71;648354]I was thinking about trying one of those was not sure how good it would work. May pick one up.[/QUOTE] They work everywhere especially behind the rotors on the hubs. Wash it out when done and when worn out replace with a sponge cut in a circle great tool. Fred
I just got my trike back today from the dealership. They did the 15000 mile check-up. They also did the clutch recall. Being from Iowa, I never got a chance to try it out. 5* out today. Been a record winter this year. Snow and cold. That rodent better be right about an early spring. Just saying.
[QUOTE=520fd;648547]I just got my trike back today from the dealership. They did the 15000 mile check-up. They also did the clutch recall. Being from Iowa, I never got a chance to try it out. 5* out today. Been a record winter this year. Snow and cold. That rodent better be right about an early spring. Just saying.[/QUOTE] That rodent is only 43 miles from home I plan on working on his cousins this summer just to keep the family in check. LOL
1000 mile check up, no shiny stuff in the oils, time to start riding.
1 Attachment(s)
Installed DK customs tank lift,comfort lift,floorboard extension. Took header pipe off going to cut cat out of it.
1 Attachment(s)
[ATTACH=CONFIG]67785[/ATTACH]Tank lift installed.
Ordered [URL="http://buylovejugs.com"]Mighty Mite[/URL] fans from Zook. Thanks for the help, Randy.
[QUOTE=graygoat;649786]Ordered Mighty Mite fans from Zook. Thanks for the help, Randy.[/QUOTE]
It was good talking to you Jeff, thanks. Your Mighty Mites are on the way.
