[QUOTE=MickUpi;772751]How often should the diff gear oil need to be changed? I was thinking it is about 50k.[/QUOTE]
I think 50K on gear lube would be OK, it does not live in as hostile an environment like engine oil;) AS long as water intrusion is not a problem you should be good to go
I was told 50,000 by Road Smith when they delivered my trike
I have done mine. Having the correct socket and ratchet is a plus. If I remember correctly I used a deep socket. Go to the auto parts store and by the hand pump, I already had this pump for changing transfer case fluid on my Tahoe. If your case has gathered a lot of road crud, clean off the bottom to find a small drain plug. This plug may be flush with the case. An Allen wrench is needed to pull this out.
tried to go to page 2 but it would not go anyway I tried to get there.
tried 2
tried next page
nothing worked
last post I could see was #10
Bubber
