2010 tri glide 103 ticking noise sounding like a lifter
well a couple of years ago I mentioned about how I had a lifter noise off and on and had taken it to the shop and they couldn't get it to do it, well its gotten a little worse where you can here it more often now , took it in and they said the valve seal was bad and valve was floating and the warranty people want them to go deeper in it like checking the cams and rods , the trike runs great except for that annoying ticking sound I would hear on start up and when cruising and let off the throttle , has anyone experienced this problem and did it get fixed ,wondering when its fixed if I'm going to end up with this problem again after all the warranty out sounds like it might be a very expensive fix
