[QUOTE=FuzzyWuzHe;669344]I'm not positive ... but I'm not sure road smith is around anymore.[/QUOTE]
What you smok’n Fuzzy? They are a big sponsor right here on TrikeTalk and are one of the top trike kit manufacturers.
Printable View
[QUOTE=14 trike;669224]My Question. I have Rushmore ultra limited 2014. This is the first one built by road smith. When I put it in reverse even in neutral the horn sounds. What should I check.
Thank you[/QUOTE]
It might be a safety feature. Below is from their website:
[QUOTE]Electric Reverse
A unique and cool option we have developed is our Electric Reverse System. This electric motor is not just a starter motor, but rather an extremely high torque 12V motor that goes through a gear reduction to produce huge torque. To operate the reverse, simply lift the lever on the left side to engage the electric motor's gear directly into the front of the belt's sprocket. One you've engaged the motor simply push and hold the bike's horn button down to back you up. When done, put the engagement lever back down and the horn button will be a horn button again.There is a safety built in so if you put the bike in gear while the lever is up, the horn sounds! You'll probably only do that once.[/QUOTE]
Hmmm, when was this quote dated, and no, they don't seem to be around even though they are a sponsor. Sure, pick up the phone and call, then it's not shared with the forum and that's what the forum is for. I read a lot here lately about Harley, and that's fine, but there are other three wheelers in the mix. They were a no show at Americade, closed the original trike shop in Daytona, jus sayin'. Maybe it's all economics. Wait, I saw the OP first post, wow, that goes back a few years.
Sorry I was not clear, was referring to Road Smith.
Doing some read back on this thread, and I found that the original 'trike store' was replaced by All Out Power Sports, whose folks now do RS fix and conversion, so I didn't want to leave the impression that they are no longer in Daytona. If I did, apologies all around.
Roadsmith is alive and well.
They are a big sponsor on TrikeTalk. If you will click on Forums, then look to your right you will see their advertisement.
Click on it and you will be in on their website with all kinds of information - including phone numbers you can call to make inquiries directly to them.
I didn’t look at their specific hours of operation but possibly they don’t respond on weekends.
