After talking with zook and hhi, I am going to install the new 6 degree trees next week with the stock length tubes.
will let you know how it turns out. Thanks for the input.
. Dago
Printable View
. Dago
cool take your time its not that hard. steering head nut torque very important.
After talking with Zook and HHI I will install next week just the 6 degree trees and see if it improves the turning.
I will let you know how it goes.
[QUOTE=dago713;766885]After talking with Zook and HHI I will install next week just the 6 degree trees and see if it improves the turning.
I will let you know how it goes.[/QUOTE]
this like "if you ride a bike, not a matter of IF you get rained on but a matter of WHEN"
For the new trees it not a matter of IF it will help but a matter of HOW MUCH it will help
you WILL be surprised i am sure
I had the new 6* trees installed to replace the 5* trees. The old trees had one fork tube crushed into a deep divit. The spring was a bitch to remove. It seems the spring would not fully expand after a bump and always had a load on it.
The trike now has good rebound and dampening. The change in handling has improved .
I now know the way a trike should feel when set up properly.
The bad thing is that the original owner spent good money to install the 5* trees only to have the the guy over tighten the the lower tree bolt causing the rough ride.
I am happy the way it turned out.
Thanks for all the helpful ideas from everyone. Dago
