Tri glide DK customs axle bearing retainer plates covered by HD extended serv. plan?
Hello fellow trikers
So I need to replace the axle bearing retainer plates on my 2019 Tri Glide, will my extended service plan cover the expense of replacing the axle bearing retainer plates if I get the DK customs axle bearing retainer plates ?? Thank you all in advance for your input.
El Lobo
Upgraded Component Coverage
USWC's Eagle Guardian Plan provides coverage for virtually all factory approved and factory or dealer installed electrical, electronic, hydraulic and/or mechanical parts essential to the operation of your motorcycle. There are a few exclusions, that are listed on page 12 of the [URL="https://536371c2-0492-4a5b-9eed-bafb0ed3474c.usrfiles.com/ugd/536371_398ba230ad50476a9693bfb912c5ce64.pdf"]Contract Booklet (LINK HERE).[/URL] (final drive belts, clutch plates, non-hydraulic hoses, ect)
The Eagle Guardian Plan doesn't require the component to be covered by the original factory warranty. This gives the rider flexibility to upgrade their motorcycle accordingly. There are Pros/Cons with every plan available; however, the Eagle Guardian and Eagle Plus plan are excellent options.
