[ATTACH=CONFIG]100917[/ATTACH]-[ATTACH=CONFIG]100918[/ATTACH]-Mounting the J-Box3 with Main circuit breaker and Terminal bar inside and all is square to the swing arm, :D-:clapping:
Printable View
[ATTACH=CONFIG]101007[/ATTACH]Motor location and chain alignment Steel plate .312/.250, drawing to machinist for chain adjustment grooves, Ordered the master link, :Coffee:
2021-07-20[ATTACH=CONFIG]101032[/ATTACH]-2021-07-21[ATTACH=CONFIG]101055[/ATTACH]2021-07-23-[ATTACH=CONFIG]101116[/ATTACH] J-Box covers are on, More mock up, and waiting for the master link...:clapping:
[ATTACH=CONFIG]101174[/ATTACH]Master Link and chain completed, Painting the tail light (LED) bracket that will bolt to the rear seat bottom-[ATTACH=CONFIG]101194[/ATTACH]-[ATTACH=CONFIG]101195[/ATTACH]Even the lights have reflectors, And I think the rear reflectors are suppose to be red?:pepper:
[ATTACH=CONFIG]101243[/ATTACH]-Horn Time- This was suppose to be easy,:gah:
[ATTACH=CONFIG]101269[/ATTACH]Damn Horn,:gah: Will not work with metal bracket (second one) So I cut a piece fiberglass off the left overs from the fender and mounted the horn to it in the center, (works,:clapping:) So now to mount it up and wire it. :pepper:
[ATTACH=CONFIG]101481[/ATTACH]Drawing and working on the pedestal mount for the 3 switches, 1.Forward-brake-Reverse. 2. Speed 1-2-3, 3. Lights-Brake lever and foot, Flashing- Tail- Headlight...EDIT:[ATTACH=CONFIG]101532[/ATTACH]-:gah:
[ATTACH=CONFIG]101990[/ATTACH]Hi guy's long time running, smashed my big toe really good 2 weeks on the sofa (drawings time) did not want to go through the process of Aluminum Rec tubing so I doug out the extra J-Box and mounted the forward-Reverse lever and the Speed 1-2-3 and for now I'll wait on the lights, just the horn and maybe the flashing tail lights. These projects are up for sale because the rents here are going crazy high so I'm going to try and buy one of those SmallHouses and add he-shed/carport? and rent space or buy?
Glad you’re back. Good luck house shopping. :wave4:
[ATTACH=CONFIG]102198[/ATTACH]-[ATTACH=CONFIG]102199[/ATTACH]-[ATTACH=CONFIG]102202[/ATTACH]-I still hate wires, :gah:
