Thanks for the post . . . I was concerned as well about the gas smell. New FW owner.
Printable View
You have to understand the gas tank is just over the hot engine, So some gas smell will happen, Especially if the gas in the tank is low..[Vapors] Un-like cars where the tank is in the back away from the hot engine...Some CanAm Spyder's were notorious 'for that [I had one]..And the 2013 were a fire hazard...
Hello, I'm new to this forum and new to the trike, just got it and first day out while riding I could smell gas. Just before i parked it i noticed it had spit and splatted gas from under the cap onto the tank. It was not over full, and it was not hot out it was about 18 celcius. It was also hissing for a long time after parking. Took it out a couple days later and it did the same thing. We took the seat off and hunted high and low for a vent tube and never did find one. Anyone know where it might be? We also loosened the tank to lift it a bit and look under but still didn't find it.
Last night had a look at the cap and compared it to the cap on my husband's Softail and found the seal that is supposed to be at the base of the cap seems too big on the FW cap it's sloppy and I can easily slide it up and down, it's tight and stays put on the other one. I'm wondering if the FW doesn't have a vent tube and has a defective vented cap instead? Forgive me if that is silly thinking, I just don't know any better but I am eager to learn and learning a ton lurking on the forums!
they had some problems with some of the gas caps. Take it in and have them change out the gas cap.
Vent tube is at the base of the tank under the seat.
Thanks I'll take that seat off again today and have a look, and I'll be sure to bring up the cap at the dealer.
i have a 2016 FW. Bought it a couple of months ago with 2200 miles on it. It now has over 6200 miles. The last couple of times I have parked it in the garage I have noticed a very strong gas odor coming from it (even had to open the garage doors because the odor was so strong we could smell it in the house). Had zero issues with this until the last two trips. I did not overfill the tank, did not splash on the tank and there was no gas dripping or leaking anywhere. On one of the occasions the tank had 45 miles to empty and now today when I noticed the smell there are 140 miles to empty. I don't want to have to leave the garage door open for several hours after we return from riding. I am concerned because there was NOT a gas smell after riding it until very recently. Any ideas?
[QUOTE=rhino 2;446389]You have to understand the gas tank is just over the hot engine, So some gas smell will happen, Especially if the gas in the tank is low..[Vapors] Un-like cars where the tank is in the back away from the hot engine...Some CanAm Spyder's were notorious 'for that [I had one]..And the 2013 were a fire hazard...[/QUOTE]
Our Freewheelers run hot! Mine is a 2015 and has the DK 2" tank lift before the tank lift sometimes I would hear a hissing sound coming from the gas cap. If you open the gas cap it relieves the pressure. I'm in AZ it was hot out! The bottom of tank was very warm!
With the 2" tank lift the top of the engine is exposed and looks better and easier to shine up! The lift also allows more cooling air to flow over the heads!
I have recently installed the Love Jugs mighty mights and with the summer heat here and fans on running; and off with ignition switch I have not noticed any of this hissing from the gas cap. My cat is still in header! It gets Hot like 497deg when shut down!
I am not affiliated with DK in anyway but I have installed every thing but an additional oil cooler that they recommend! Check them out they have a lot of good info on cooling the Freewheeler! They are sponsors on this site; very helpful and good products!
Dave
[QUOTE=firebikerd;489019]
[B]I have recently installed the Love Jugs mighty mights and with the summer heat here and fans on running; and off with ignition switch I have not noticed any of this hissing from the gas cap. My cat is still in header! It gets Hot like 497deg when shut down![/B]
Dave[/QUOTE]
Glad to see the Love Jugs eliminated the heat and stopped the hissing and gas smell Dave.
The fans direct a steady and massive amount of air directly onto the source of the heat which is the ignition area, the spark plugs and the cooling fins, both on the front cylinder and the real hot spot, the rear cylinder.
The Mighty Mites spin at 13,000 RPMs and as Kevin's test reports show, they drop the cylinder temps buy 72 degrees. Some folks, Kevin included, wire their fans to stay on after the bike is turned off so the fans can run a few minutes to further cool the engine down, eliminating the heat and pressure build up.
[ATTACH=CONFIG]47160[/ATTACH]
Papa Zook
The Mighty Mites work! I generally switch to Acc. when shutting down; for a few mins. It's been in high 90's and that rear cylinder shut down is active now; but has not happened yet! Leaving for Sturgis in AM and will see how it does on the trip! The town of Sturgis can be very slow going! Denver too!
Have a good day!
Dave
