I started to rebuild my trike, the frame is ready to go for blasting so i decided I would look at the motor today. while looking at the motor I removed the oil screen cover there was more metal there than I was comfortable with. I started looking I found 2 loose head nuts on one side and 1 on the other so I removed the heads. I removed the cylinders and found the wrist pin clip missing on #2 cylinder. I then kept going splitting the case. The cam bearings looked worn out the mains do not look bad.
Now what should be my next step?
Take the case to machine shop for evaluation?
