BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  2
Results 1 to 11 of 11
Thread: Strobe brake controller 2007 Tri Glide
    Jun 2019
    Washington
    Default Strobe brake controller 2007 Tri Glide
    We bought a 2007 Harley Ultra Classic Touring with a Lehman Renegade Trike Kit (Tri Glide right) anyway, we are having issues finding a strobe controller that will handle the wattage of four incandescent 1157 bulbs. the 1157 incandescent bulbs are rated at 27 watts. Times that by four because of our touring kit equals 108 watts. The controllers I've seen can only handle 80 watts. So what is one to do? Very important NOTE, is the year of our bike 2007, number of 1157 bulbs (4) and the total wattage brake light strobe controllers can handle (80 watts). Please help!
    Thanking this group in advance,
    Mike R
    The West Coast Washington
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by Mike Root View Post
    Mike R
    Why can't you use LED replacements for the 1157 bulb ??
    Jim Murphy
    Iron Butt Rider 2001
    Jun 2019
    Washington
    [QUOTE=Lee H. Mann;675985]Why can't you use LED replacements for the 1157 bulb ??
    Lee, do you have a brand and part number for the bulb shown in your reply?
    Thanks for your help,
    Mike R
    Jun 2019
    Washington
    [QUOTE=Mike Root;675995][QUOTE=Lee H. Mann;675985]Why can't you use LED replacements for the 1157 bulb ??
    Mike R
    Lee,
    I forgot to ask, will I need a resistor to use this bulb? If so can you recommend a source for it. You need to know your talking to a beginner with this task.
    Thank you.
    Mike R
    Apr 2010
    Shenandoah Valley of Virginia
    "Strobe brake controller"?
    Jun 2019
    Washington
    That's what i'm going to try, but ill have to figure out which resistor to use so the strobe unit doesn't flash to fast.
    Mike, when choosing bulbs have a read here
    Which Color LEDs Should I Use?
    For best results, the LED color should be the same as the lens color. If the bulb is behind a clear lens, use the appropriate color for turn and brake light functions.
    When installed in a housing that has a matching colored lens, red and amber bulbs will appear brighter than white LED bulbs—even though they have lower lumen outputs.
    As an example: a red lens will filter out all but the red portion of light from a bulb, so if the light being emitted from the bulb is all red, none or very little light will be blocked by the lens. The light from a white LED bulb contains very little light in the red portion of the visible spectrum, so most of the light that contributes to its higher lumen value would be filtered out by a red lens. This makes the white bulb appear dimmer than the red bulb.
    Jun 2019
    Washington
    Thank you for the information, I am now planning on using ZEVO 1157 bulbs. Do I have to use a resistor with them? And are you saying you "Do Not" use s strobe controller on your bike?
    Mike R
    Mike R
    I do NOT use a strobe on mine
    The brake lights use less current also , a resistor or load equalizer will be needed
    100+ Posts
    Apr 2019
    Lewisville
    Default Available at most auto parts stores
    [QUOTE=Mike Root;675997][QUOTE=Mike Root;675995]
    Mike R
    Lee,
    Thank you.
    Mike R
    This part is available at most auto parts stores. I used them in several bikes over the years. Replaces the standard 1157 bulb, no other mods needed, just plug and play.
  1. strobe brake light kit
    By Mike Root in forum New Member Introductions
    Last Post: 06-12-2019, 06:39 PM
  2. Replies: 2
    Last Post: 02-03-2017, 12:27 PM
  3. LED Strobe Lights
    By sarge7882 in forum Harley Trike Conversions
    Last Post: 06-19-2012, 08:30 AM
  4. JM GL1500 CB, Volume, Mic On/Off Pass Controller
    By retdpd in forum Honda Trikes
    Last Post: 09-24-2010, 07:06 AM
  5. Gerbings temp-controller
    By DJS in forum General Discussion
    Last Post: 06-13-2009, 11:38 AM
