Likes Likes:  4
Thanks Thanks:  1
Results 1 to 18 of 18
Thread: See the pic
    150+ Posts geraldlanc's Avatar
    austin tx usa
    Default See the pic
    My new to me 2008 CSC has led strip lights from end to end, but not working. Looking at the battery, there is wiring to the neg terminal that is spliced ( see the pic ). It goes down to a fuse at lower right. What is it? I removed it at the fuse panel and everything still worked. Could that be wiring for the led’s ? I don’t like the way it is spliced, so I might just remove it. Any thoughts?
    GeraldName:  A8A1280B-1773-4916-A9AF-594882CC6D1B.jpg
    Quote Originally Posted by geraldlanc View Post
    Could that be for the led strip and the fuse is blown.......
    austin tx usa
    Default See the pic
    I checked that fuse, it’s good
    Just for chance did you pop in a New fuse......
    austin tx usa
    I don’t have a spare, so will have to wait on that. I tested the fuse, it is good, however
    Ok.....Thats all i got.........When you do get to the bottom of it let us know...
    60+ Posts Rally's Avatar
    Nov 2010
    Elkin, North Carolina, USA
    Have you tried changing the polarity?
    2016 H-D Tri Glide
    TOI #00485
    800+ Posts Motorcycle Mike's Avatar
    Jul 2014
    Lawrenceville, Ga
    Is that red clip an alligator clip?
    If it is that is the likely culprit.
    I would redo it anyway.
    You don't quit riding because you get old.
    You get old because you quit riding.
    Mike & Shirley
    austin tx usa
    Default The latest
    So, I removed all the wires in the pic, leaving only the factory + and - wiring. Everything factory works. The PO had installed a sat radio as well as the strip lights so I think those were the “extra” wires at the battery. For now I am going to leave those wires disconnected and push them out of the way. I would like to remove them entirely, but that would mean removing some body parts.
    Gerald
    Quote Originally Posted by Rally View Post
    Gerald. It looks like the PO installed one of the 2 items first attaching the cream wire to the ground side of the battery. Where it goes and which wire is the hot for that item I can nolt tell from the pic. They then come along with that black wire with the 2 wires coming out of it on the top left. They attach the red side to what most likely is the hot "+" side of the fuse box. They attach the other to the previously mentioned cream wire with what it know as a wire splice. In that situation who knows why not just put a lug on the wire and attach it to the ground terminal.
    I do not believe that cream wire coming off the ground side goes to the mentioned fuse. They look like 2 different color wires one with a strip on it. If it did it would blow that fuse immediately because that is a direct short from positive to ground. I agree they have something to do with add on items which is why your factory stuff works with them dis-connected.
    You will have to remove stuff and trace the wires for a solution.
    4750+ Posts
    Mar 2015
    Texas
    I've asked some questions in the following photo...
    oops.............................................. .................................................. ..........................white wire
    American Legion Rider
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Gerald.. you are in Austin, I am in Kerrville... if I hear a big boom from that direction I will know you probably should have called the bomb squad first to remove it...then started over....
    Quote Originally Posted by paws View Post
    One thing i learned from watching Mission Impossible' Bomb deactivation 101' you should always snip the red wire first........
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    It's an aftermarket self destruct mechanism. Harley's have one built in. They're placed in a random sequence during manufacture and seem to work quite well.
    austin tx usa
    Default My brain hurts
    So after removing these wires, went for a ride, everything factory was working. Did not check the radio. On a ride this morn, turned on the radio but it only worked with the clutch in, in neutral, or the turn signal activated. Got home and unwrapped the extra wires, but did not reattach them to the battery, and the radio then worked. At least this keeps my old brain working. I think I will just reattach them and be done.
    Sounds like the previous owner was Rube Goldberg😁😁..
    austin tx usa
    Default One more reply
    Located the problem, blown fuse under the seat. Replaced it, and there was light. Problem, the ignition switch was in the off position. I removed all the wires, connected the red from the fuse to the hot terminal on the fuse block and the black from the fuse to ground. Now they lite up only with the ign switch on. The rest of the wires in the pic are for now not connected to anything.
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    I can tell you that the reason they only come on with the ignition on is because of that red positive wire that is connected to the screw on left side of the photo. That screw at the top left of the factory fuse block is only live when ignition on or in ACC position.
    You mentioned a fuse under seat that was blown. Is that a single fuse like the one in front of the battery or is it on an aux fuse block? I might suggest if it is a single fuse, why not add an auxiliary fuse block instead. You could fuse it directly to the battery and then it would be live all the time. That would give you options
  1. Not sure where to post this pic...
    By Ozarkryder in forum General Discussion
    Last Post: 08-15-2009, 06:10 PM
  2. John now you gotta pic a BG
    By robandlyn in forum General Discussion
    Last Post: 07-04-2009, 08:39 PM
