Likes Likes:  505
Thanks Thanks:  39
Page 23 of 26 FirstFirst ... 13 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 441 to 460 of 504
Thread: Rebel RT
  1. #441
    600+ Posts TomyJ's Avatar
    May 2016
    Hemet, Ca. USA
    Default Damn Battery
Size:  669.6 KB-On hold again so I'll be back on the eScooter wiring for a couple of days,
    JakeJacobsen@Pinterest.com
  2. #442
    May 2016
    Hemet, Ca. USA
    Default eScooter
    Waiting a couple more days for the Battery, so to keep busy I wired the on/off switch and the external Batt charge terminal.Name:  eScooter wires.jpg
  3. #443
    May 2016
    Hemet, Ca. USA
    Default Wiring
Size:  750.6 KB-Wiring back at it with new battery...
  4. #444
    May 2016
    Hemet, Ca. USA
    Default eScooter
Size:  287.9 KB-Name:  HPIM4839.jpg
Size:  841.1 KB-Name:  HPIM4840.JPG
Size:  864.4 KB-The eScooter is off and running with the new batteries and wiring, one week for shake down then up for sale, But a neighbor with a bad hip wants first shot ($) at it... Back on the Trike and the gScooter on the side. EDIT: SOLD 11-02-2020
  5. #445
    May 2016
    Hemet, Ca. USA
    Default gScooter
    Name:  1-gScooter Lside.JPG
Size:  960.0 KBNeed to fix the fuel problem with this than sell, 50MPH, Motorized Scooter (platform)according to the DMV, legal. Back to the Trike wiring...
  6. #446
    May 2016
    Hemet, Ca. USA
    Default Wiring
    One thing this Trike wiring has taught me is IF you are not in the mood, do something else because you'll F-up...Name:  Wiring Nest.JPG
Size:  958.0 KB-Name:  Running lights.JPG
Size:  679.5 KB Rear running lights and foot brake light all dialed in, Please remember this building a reverse trike from scratch is all new to me so bare with me when I enjoy simple pleasures, AND wow I made it work!!! That's NOT what I tell my wife, speaking of her she would not drive the eScooter to speed again 25mph, she just wants a one speed bicycle and she's happy! SOOOOO! I ordered a 24" Tricycle 7 speed (she will not shift it" and soon a eBike kit for 48V 20Ah 1K Watts li ion Batts, I'll be hoping to put it together and sell to the local senior citizens, I know we can all use a little extra income...
  7. #447
    Thumbs up
    Looks like a good job
  8. #448
    May 2016
    Hemet, Ca. USA
    Default eTricycle
Size:  964.1 KBStill waiting for wiring parts for the RT so here's another side job for the wife.-Here's the foundation for the 24" eTricycle. eBay and it comes 75% assembled, I think the hardest part was the Shimano 7 speed detailer and the chain, they did supply the chain breaker (aka installer) AND Don't ever forget the pedals are left and right hand threads. So we will be test riding it to make sure nothing goes wrong then order the front wheel eBike kit and the battery's. 1K Watt motor, 48 Volts, 20Ah Lithium Ion batteries, Ohhh Yeaaa!!!
  9. #449
    May 2016
    Hemet, Ca. USA
    Default Rear Wiring
Size:  954.7 KB-Lets see if just the junction box will work?
  10. #450
    May 2016
    Hemet, Ca. USA
    Default Wiring
Size:  715.7 KBNow back to the wiring...
  11. #451
    May 2016
    Hemet, Ca. USA
    Default Wiring
Size:  669.7 KB-Name:  2020-12-09 Rear lights work.JPG
Size:  671.3 KBRear wires are finished, before I start on the front and taking off the gas tank, I'll try to start it? tomorrow?
  12. #452
    May 2016
    Hemet, Ca. USA
    Default Engine runs
    Name:  RT Engine runs.JPG
Size:  806.5 KBYea!!! Engine runs, Now on to the front wiring tomorrow, then fill and bleed rear brake...I love to pat myself on the back,
  13. #453
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    Getting close to a ride! Looking forward to a video!
  14. #454
    May 2016
    Hemet, Ca. USA
    Default RebelRouser
    Name:  2020-12-14 wiring.JPG
Size:  769.1 KB-Ohhhhh! Do I hate wiring, -Maybe this new tank will make up for it today, checking for petcock leaks, ready to install after the F****** wiring, Wife's got me on "HONEY DO" this week because of Xmas...Name:  2020-12-14 new gas tank petcock.jpg
Size:  653.9 KB-Damn it's getting cold in the "ManCave"
  15. #455
    May 2016
    Hemet, Ca. USA
    Default RebelRouser
    Name:  2020-12-20 Seat and Box.jpg
Size:  752.3 KB-Name:  2020-12-20 Headlight on.JPG
Size:  652.5 KBWow these 7" headlights look a lot better than the 5" one on top, now to wire it up and then the gas tank and fill bleed the rear master cylinder and brake caliper, THEN, THEN, let the good times roll, I will be the "REBELROUSER"...
  16. #456
    look good can't wait for the test ride results
  17. #457
    May 2016
    Hemet, Ca. USA
    Default RebelRouser
    Name:  2020-12-21wires gas tank ft brake.JPG
Size:  792.7 KBNew tank installed and wires tucked under it, foot brake master cylinder filled and bled, NOW of all times there is a problem with the signals, my 2000 bike does not have LED lights, BUT I did put on new signal lights LED and they do not flash because of LED, used jumpers on old lights and they flash. HELP! What do I have to do to get them to flash???
  18. #458
    Quote Originally Posted by TomyJ View Post
    Led lights use low voltage. You will need a load equalizer to make them work.
    Look here https://www.amazon.com/SYLVANIA-Equa...8609126&sr=8-3
  19. #459
    May 2016
    Hemet, Ca. USA
    Default RebelRouser
    Thank you Jack, You know I am lost with this wiring mess? Can I use this as one unit from the switch or one per light??? DAMN! I hate wiring,
  20. #460
    I would say 1 per circuit
