Likes Likes:  189
Thanks Thanks:  13
Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 21 to 40 of 145
Thread: TriPod
  1. #21
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by TomyJ View Post
    Attachment 95307-Attachment 95308 Swing arm mockup, The Wife say's this will also hold the basket? If I put a alum. diamond plate cover between the 2 arms it might work...
    i would shy away from rod ends for wheel bearings.. they might last forever in this application... but this is not what they are mad for! checked the speck and i did not see any speck for rpm.. usually if something is meant to spin there is a speck... as i said with a light load an low rpm they might last for ever but personally i wouldnt want to zooming down the road an have one fail
  2. #22
    600+ Posts TomyJ's Avatar
    May 2016
    Hemet, Ca. USA
    Default TriPod
    Name:  2021-02-06 shock mock up.jpg
Size:  656.6 KBNow you know WHY I call this mock up...EDIT: Need's to be changed to a swing arm style? Bellcrank?Name:  1a-RT Rear coil over Assy..JPG
Size:  808.5 KBMaybe put the control arms/swing arm inboard and the shocks running outside along the frame?
    JakeJacobsen@Pinterest.com
  3. #23
    May 2016
    Hemet, Ca. USA
    Default TriPod
Size:  960.4 KB-Name:  2021-02-08 Rear 8.5 control arms.jpg
Size:  767.3 KB-Name:  2021-02-08 Side 8.5 control arms.jpg
Size:  710.2 KB-Enough said...
  4. #24
    May 2016
    Hemet, Ca. USA
    Default TriPod
    Name:  2021-02-10 mock up.jpg
Size:  751.9 KBName:  2021-02-10 mock ups.jpg
Size:  715.0 KBName:  2021-02-10 seat mock up.jpg
Size:  719.7 KBName:  2021-02-11-105 Forks in storage.JPG
Size:  801.3 KBPreWeld-I love building cool things. My wife say's I need to get a life...
  5. #25
    May 2016
    Hemet, Ca. USA
    Default TriPod
    Name:  2021-02-13TriPod Mock up shocks.jpg
Size:  682.7 KBShocks will go something like this, change the control arms to a swing arm design and place the shocks beside the seat post area and fit the batteries in there also?
  6. #26
    May 2016
    Hemet, Ca. USA
    Default TriPod
    Name:  2021-02-14-216 Ready for weld.jpg
Size:  676.0 KBTime for "DISASSEMBLE" Welding soon,
  7. #27
    May 2016
    Hemet, Ca. USA
    Default TriPod
    Name:  2021-02-17-223 Ride heigth final.jpg
Size:  742.0 KBFitment for lower/upper frame headstock...
  8. #28
    May 2016
    Hemet, Ca. USA
    Default TriPod
    Name:  2021-02-20-231 Seat frame.jpg
Size:  696.4 KBSeat frame...
  9. #29
    May 2016
    Hemet, Ca. USA
    Default TriPod
    Name:  2021-02-22-244Mock up fork and angle.jpg
Size:  716.9 KBMore mock up. Ordered the Monarch forks today, already ordered the Worksman wheel with drum brakes, tire, tube and rim liner. Dropped off swing arm for welding and fitment, All should be installed by late next week...
  10. #30
    May 2016
    Hemet, Ca. USA
    Default TriPod
    Name:  2021-02-24-250 Frame tack weld.jpg
Size:  745.8 KBFrame is tack welded, nice to have the clamps out of the way and the Heim Joints bolted to it. Still waiting for the Monarch Springer Forks and front Worksman wheel, BUT on the good side, NEW Bell Comfort Bike Tire 26" Carbon Steel Bead Bicycle Wheel 1.75" - 2.25"tire, Bicycle Inner Tube GoodYear 26" x 1.9" to 2.3" Heavy Duty 30% thicker, free shipping, and liner has come in...
  11. #31
    2000+ Posts trikeman's Avatar
    Oct 2010
    Jackson Tn. Madison Co.
    I’m not questioning your design,just curious about the layout of your shocks. In every application I’ve noticed it seems shocks were usually in the vertical position. On a few applications such as the IRS on the CSC Trike they incorporated a mono shock in a horizontal position above the rear differential with the left and right side upper A-Arms attachments to opposing ends of the shock. In my limited knowledge I don’t see the rear suspension benefiting from the design pictured. Again l’m NOT questioning your design, just curious.
    PS,,,,, I enjoy watching all your threads on your builds.
  12. #32
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by trikeman View Post
    one thing is the height
  13. #33
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    another consideration is the fine tuning of a heavier shock/spring into a lighter one by laying it over at the angle that gives the right support and travel to the suspension.
  14. #34
    May 2016
    Hemet, Ca. USA
    Default TriPod
    Name:  2021-02-27-256 Shock mounts.JPG
Size:  850.7 KBCan you see where I am going with these shock mounts? right one will be adjustable for ride attitude... Going to look pretty cool HUH!!!
  15. #35
    Oct 2010
    That pic helps. Post #30 was the pic I was confused by.
  16. #36
    Oct 2010
    But I live in a state of confusion
  17. #37
    May 2016
    Hemet, Ca. USA
    Hi David, thanks for stopping by, The reason I am leaning the shock is for looks, It will help give it the wow effect as will the bicycle springer up front, the batteries will go under the shocks and the seat above. I thank all you guys for your support on this build and the others... TrikeMan did you see my 1st trike in "Introductions"? Red fiberglass body sim to yours all hand made, yes it took a while, EDIT: And don't be so hard on Tn.
  18. #38
    Oct 2010
    I’ll check it out. I was confused before I got to Tn
  19. #39
    May 2016
    Hemet, Ca. USA
    Default TriPod
    Name:  2021-02-28-261 SwingArm.JPG
Size:  967.8 KBNow I can call it a swing arm, need to figure disc brake and sprocket soon,Name:  2021-02-28-261 Mock up Springer.jpg
Size:  801.5 KB-Name:  2021-02-28-259.jpg
Size:  756.1 KB Got in some serious mock up time in today, tomorrow machining and weld for shock mounts, AND near ready for Alum. weld for the head stock frame, then weld to frame and set up the frame gussets.
  20. #40
    May 2016
    Hemet, Ca. USA
    Default TriPod
    Name:  2021-03-01-263 Springer&Wheel.jpg
Size:  794.9 KBOhhh Ya! Now this is the look I am after (BigWheel), Can't find a goose neck I really like? Then I'll set it up with drag bars or may be pull backs, Dropped off the brackets for the shocks at the welder then the alum mount and frame welding, HappyHour with a smile...
