I really must stay away from on line forums, you tube etc. By chance I have become aware of the issue of oil sumping on the M8 engines. There are threads that imply engines will be destroyed, others that its not a common issue etc etc. Opinions state it is more likely if the nike is driven at high revs for long distances. Threads also suggest it affects most / all engine models while cures appear to focus on an updated oil pump. Had some input from Dwayne at DK Customs which helped but not am hoping that forum members might be able to give a definitive summary.
My Tri Glide (which has just had a Stage 1 upgrade fitted) was built late December in 2017. I spoke with my local dealer who told me the issue is oil getting from the gearbox to the Primary. Is this the same issue or another????? The guidance from the dealer was -
Check gearbox oil and make sure it is correct
Drive 1000 miles and check again.
The oil level at this point will tell whether there is an issue….. or not!
With a 3 week two up tour of Spain booked for the coming summer, I am anxious to pre empt any issues if they exist and put my mind at rest! Can any members suggest if -
I am likely to have a problem?
I don't need to worry?
I should be take certain steps to “future proof” the bike - upgraded oil pump for instance.
Your thoughts and opinions appreciated!
Bob
Bob
